Modular V10 (6.8l)
3V blower thought
Old Oct 17, 2006 | 01:35 PM
Kerr's Avatar
Kerr
3V blower thought
I posted this in the wrong section last time:
So i finally got around to talking to ford uy in town. This guy does all the work on lightnings and cobra, as well as other ford vehicles.
I mentioned that no makes a blower for the 05 up v10's. He said " thats because they went to the 3 valve head which made the front of them motors different that 2 valve head's". He then went on to say " as far as forced injection goes it shouldn’t matter if you can mount the blower, or Turbo I have done 4 F150's with the new 3 valve heads and they all work fine with a porcharger set up, one should be able to buy a bigger blower for the F150 to make up the cubic inches and then have a adaptor plate made to mount the blower. Im sure there will be a few little problems here and there you have to work out but if you have the blower set up the little problem are just that little problems. Then you can use a STC programmer to tune the fuel delivery. I’m not sure how much fuel those injectors and pump flow so that might also be something to consider. Main thing is that if you can get the blower, turbo some one should be able to make it work".
So what do you guys think. I know that a $5-6K blower will put us almost back to the cost of the diesel, but you will never have the instant torque of the v10.
On a side note, does anyone have a F250 crew with the 4:30 gears? I just looked a 07 V10 sport crew with 4:10's which has no problem spinningon accident, the sales guy said yea they are torquie and the 4:10's help it, you should drive one with the 4:30's!<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old Oct 17, 2006 | 05:52 PM
gaspowerSD's Avatar
gaspowerSD
But if for some reason it doesn't work out what happens after you have spent all of that money and torn apart your engine? Does anyone know if maybe kennebell or others are working on 3v blowers? I would sure consider buying one for my truck. Anyone with a blown 2v have comments about the power difference? can you really feel it that much?
Old Oct 17, 2006 | 09:30 PM
NoMo's Avatar
NoMo
The ProCharger and Magnacharger have been adapted to fit various vehicles for which they weren't necessarily designed. So I'm pretty sure you could do it if you want.
Not sure how the rest of the driveline would handle the added power, but I'm sure I know what Ford would do about your new truck's warranty!
Old Oct 18, 2006 | 06:52 PM
captchas's Avatar
captchas
Guest
forget the warrenty with a blower setup. jury rigging. i personly am not into so i'll simply wait of whipple to get the kit they are working on to the market.it's only 2 years late now but is in the carb checking works.
dssocialwrk
Nov 30, 2018 04:55 AM
jtcdudeman
Sep 16, 2016 01:05 PM
kwdoc
Aug 2, 2010 09:29 PM
yaki69
Sep 30, 2006 02:06 PM
