Transfer case swap question
Old Dec 9, 2015 | 09:29 PM
pcpotter1023's Avatar
pcpotter1023
I have a '91 F250 7.3 IDI 4X4 I bought a '95 with a 460 CI engine that I was going to get running but it has more issues than I want to contend with I know the E4OD trans want fit the 7.3 (shucks) , my question is this, will the transfer case fit the 5 speed trans behind the 7.3 IDI, I'm wanting to swap them out because the previous owner did away with the protective plate the '91 and well you know the rest of that story on the transfer case, it's not broke but it has been scuffed pretty good.
Thanks
Patrick
Old Dec 9, 2015 | 11:29 PM
BruteFord's Avatar
BruteFord
Yes, and no on the transfer case, it will bolt up to the ZF but the 95 doesn't have the gear inside for the speedo drive and I think the front drive yoke is a different size. I think it can be done with some parts swapping, I need to do this myself I have a 92+ TC I want to put in my 89 but that's a back burner project.
Old Dec 10, 2015 | 12:26 AM
pcpotter1023
I'd already looked at the tail and I'm going to put my old one on the newer transfer case, or at least that's the plan as long as it fits.
Old Dec 10, 2015 | 12:37 AM
BruteFord's Avatar
BruteFord
There's a hole in the tail shaft that indexes the gear, I just can't be sure that that whole was drilled in later cases. If the whole is there then yeah swap the gear and tail housing, if not maybe drill it.
Old Dec 10, 2015 | 01:03 AM
Willz74's Avatar
Willz74
The hole is there but it's not in the tail housing so you will need that
that-1redneck
Jan 25, 2012 09:17 AM
Michael Ides
Jun 12, 2010 07:39 AM
jmbfarmall
Mar 28, 2009 12:47 PM
cwpitman
Dec 11, 2005 09:58 AM
spurredon
Jul 31, 2004 11:35 PM
