4wd not working
Old Oct 17, 2006 | 09:51 AM
bad azz 1993's Avatar
bad azz 1993
4wd not working
i have a 1993 ford ranger 4wd and u can push the 4ih and the shafts want turnand when u push the 4L it goes to 2wd . i got to start driving this one i had a 1992 with 4in lift and a set of 33s and a girl hit me last night . thanks for the help
Old Oct 17, 2006 | 10:02 AM
aquanaut20's Avatar
aquanaut20
The T/C has a electrical/magnetic operated clutch (single brown wire on T/C) which is deenergized when in the off/auto position,
12vdc is applied to this clutch when switched to 4hi (no motor movement), engaging the front shaft.
When switched from 4hi to 4 low the motor turns a shaft in the T/C, changing the gear ratio.
Old Oct 17, 2006 | 10:17 AM
bad azz 1993
Thanks man for your help , so what do i need to do to fix it put a new t/c motor on the t/c or do u thank i can take it off and fix it .thanks agin man
Old Oct 17, 2006 | 11:11 AM
aquanaut20's Avatar
aquanaut20
Fist things first, check and see if you have B+ power on the brown wire to the clutch when the switch is in 4hi.
If no, find out why
if yes, then the clutch may need survicing.
Old Oct 17, 2006 | 11:47 AM
fordboy_52's Avatar
fordboy_52
Welcome to FTE badazz. Im glad you chose the best site on the net for Ford-Trucks! See you around the boards!!
Matt
Old Oct 17, 2006 | 11:59 AM
bad azz 1993
i dont want u to get mad at me man. were is the clutch in the motor or in the t/c thank u
Old Oct 17, 2006 | 02:16 PM
Alan D.'s Avatar
Alan D.
I think it's in the rear of the transfer case. it should have some wires hanging off of it.
Old Oct 18, 2006 | 09:00 AM
bad azz 1993
thanks any one have any pics . thanks for the help
