Squeek from brake pedal...any ideas??
I can't really pin point it, but it is not coming from any of the moving parts or springs under the dash on the pedal. It only squeeks when releasing the pedal. I can feel it in the pedal and it seems like it is coming from the plunger thing that goes through the firewall. I can't really get any spray in it because its tight in there.
Does anyone else have this? Is there a fix? Its annoying as hell.
It looks aligned ok to me. I'm the only driver/owner, and its a relatively new truck. Its something that has sort of developed slowly, like something needs some grease or oil, but its in the part on the firewall, not on the brake springs themselves. Can you squirt some oil in there a little and hope it gets around to lube whatever is squeaking?
Try to get a good look where the rod goes through the firewall. That is what actuates the hydro-booster. If there is any wettness it is leaking and needs to be replaced. Also, check the fluid level in the pwr steering res. as it should supply the hydro-boost also. If it low, add some p/s fluid and actuate the pedeal for a bit to see if the squeak stops. I had this prob on my 01 and had to replace the hydro booster. Same squeak.
Wes
Wes
That booster is hydraulically operated, not vacuum like gassers, unless the newer ones are different. You might try to pinpoint the squeak with a stethoscope or piece of tubing and see if that part can be lubed.
Have you checked the pwr steering res. level? Check the booster from the engine side of the firewall for leakage, also.
Hurry up and find it so we can make a new aggie joke about it! LOL
Wes
Wes
Are there any return springs for the brake once you get through the firewall?? Is there anything attached to that rod on the other side of that firewall that can squeek or be lubed?? Something in there isnt submerged in fluid, or it would leak into the cab. God its irritating.
