Sponsored by: Real Truck
Spitzlift???
Old Oct 16, 2006 | 11:55 AM
bneafus's Avatar
bneafus
Question Spitzlift???
Anyone own one or heard about them? They look pretty cool for lifting items into the truck bed. What I most want to know, is can the truck bed mount fit under a hard toneau cover. Also, how well do they work? Thanks,Brian
Old Oct 16, 2006 | 11:02 PM
bneafus's Avatar
bneafus
Anyone got anything??
Old Oct 16, 2006 | 11:05 PM
jake00's Avatar
jake00
it might take a little longer than 12 hrs to get some good responses. got a link to the product?
Old Oct 16, 2006 | 11:26 PM
bneafus's Avatar
bneafus
Good idea Jake,thanks Brother:
http://www.spitzlift.net/
Old Oct 17, 2006 | 12:09 AM
donjamer's Avatar
donjamer
I saw it on Trucks when Stacy David showed it off. It looked good but I didn't like the hand crank winch idea.. Might take alot of muscle to move the crank under heavy loads. I think a better idea is the rear bumper that has a portable crane stowed inside. It easily converts to a hoist and it looked decent..
Sorry I don't remember the name, but I believe someone on FTE posted it..
I will try and find it, but hopefully someone else has the info.
Old Oct 17, 2006 | 12:33 AM
donjamer's Avatar
donjamer
I found the link I was talking about. Not sure of cost, but I would assume they are pricey
You can check out these.
http://www.stoaway.com/
http://www.westernmule.com/
Old Oct 17, 2006 | 10:31 AM
tazo's Avatar
tazo
I bought a spitzlift a few months ago. It works great. I use it to lift my 30 gal compressor into the truck. I've also lifted sheets of sheetrock. I have not lifted more than a few hundred pounds. It works as advertised. I put the universal base in the back corner of the bed. It sits just proud of the bed rail so I do not know if your cover will fit over it. I am sure there is a way to make it work. The winch works with very little effort. I don't know how it will work with a full load since I have yet to put much weight on it. When I load my 400lb brush mower on I will let you know. It is much easier using the lift verses using a ramp. For me it was well worth the cost. Much better than a sore back.
http://www.spitzlift.net/index.html
Old Oct 17, 2006 | 11:51 AM
bneafus's Avatar
bneafus
[QUOTE=tazo]I bought a spitzlift a few months ago. It works great. I use it to lift my 30 gal compressor into the truck. I've also lifted sheets of sheetrock. I have not lifted more than a few hundred pounds. It works as advertised. I put the universal base in the back corner of the bed. It sits just proud of the bed rail so I do not know if your cover will fit over it. I am sure there is a way to make it work. The winch works with very little effort. I don't know how it will work with a full load since I have yet to put much weight on it. When I load my 400lb brush mower on I will let you know. It is much easier using the lift verses using a ramp. For me it was well worth the cost. Much better than a sore back.
http://www.spitzlift.net/index.html[/QUOTE]
Thanks Buddy, they sound pretty cool. Any chance you could get a pic of the mounting? Would be much appreciated! Thanks
Old Oct 18, 2006 | 11:52 AM
tazo's Avatar
tazo
bneafus, There are photos in my galery. The universal base sits about 3/4" above the bed rail. It is adjustable so I think it could work with a cover.
Old Oct 18, 2006 | 03:11 PM
bneafus's Avatar
bneafus
Looks great Buddy! My toneau is actually a hard slider that sits in side the rail. I know the mounting bracket is adjustable, do you think it'd mount under the rail instead of on top?? Thanks again...Brian
Old Oct 18, 2006 | 03:32 PM
tazo's Avatar
tazo
I don't see a problem with bolting the bracket to the underside of the bed rail. It just needs to be very strong due to the leverage of the lift. You can also get the bracket that attaches to the receiver hitch a bit pricey though.
Old Oct 18, 2006 | 06:02 PM
bneafus's Avatar
bneafus
Yah I saw that too...Gonna have to just try I guess...Thanks so much for your input...Very helpful!!
wellman715
Paint & Bodywork
Jun 12, 2016 09:16 PM
ddan342
May 3, 2016 06:30 PM
JamesRogers7
Feb 14, 2016 03:56 PM
Jhiles62
Jan 2, 2016 08:28 AM
woodsmoke
Jul 22, 2010 09:53 PM
