New accufab inlet pipe?
Old Oct 16, 2006 | 07:25 AM
BADAS03SVT's Avatar
BADAS03SVT
in one of my magazine I bought...I think it was Diesel Power, it replaces the elbow tube and they gained some good power all through the rpms on a 6.0. anyone have it?
also, who has the best price?
Old Oct 16, 2006 | 10:24 AM
Bear Hunter's Avatar
Bear Hunter
It is a great modification. Easy to install...looks great...and is pre-drilled and tapped to accept a boost line.
You can buy them direct:
www.accufabracing.com
Old Oct 16, 2006 | 10:27 AM
BADAS03SVT's Avatar
BADAS03SVT
[QUOTE=Bear Hunter]It is a great modification. Easy to install...looks great...and is pre-drilled and tapped to accept a boost line.
www.accufabracing.com[/QUOTE]
are the 2007's the same as the 06's?? what is the boost line for? an aftermarket guage?
also, who has some pics of theirs installed?? polished or not
Old Oct 16, 2006 | 11:09 AM
Bear Hunter
Yes the 05-07 are the same
Definately go with polished
It is pre-drilled and tapped to accept a boost line for an aftermarket boost gauge. Make sure if you order it to get the updated version with the tap at the top of the inlet (not the bottom). You don't have to use it if you do not plan on using an aftermarket gauge.
The beauty of this piece is that it looks like an engine dress up piece (polished)... In other words it does not look like a Banks elbow which could tip off a non mod friendly dealership. Accufab just designed the inlet to provide less restrictive flow. The easiest way to look at it would be to compare it to exhausts (mandrel bent tubes vs non mandrel bent tubes)
Old Oct 16, 2006 | 11:22 AM
BADAS03SVT's Avatar
BADAS03SVT
ok...the Banks one still looks restrictive?? and its Red!
Old Oct 16, 2006 | 11:52 AM
Lonewolftx's Avatar
Lonewolftx
Arrow Go 4 it . . .
Check out my gallery, there is one there. Nice piece and helps quite a bit . . .
sgrol
6.7L Power Stroke Diesel
28
Jan 12, 2011 11:39 AM
ismet7777
Jan 2, 2011 03:01 PM
jdecker88
16
Oct 2, 2008 02:14 PM
Ron Chichelli
16
May 17, 2008 03:45 PM
redbull660
Jan 14, 2007 11:11 PM
