Suppliments(Power Service)
Old May 16, 2008 | 12:24 PM
Ron Chichelli's Avatar
Ron Chichelli
What is the differance between Power Service Diesel Fuel Supplement(white bottle), and Power Service Diesel Kleen( gray bottle )? I use it in a 1999 7.3
Old May 16, 2008 | 12:33 PM
Smokin''s Avatar
Smokin'
Smokin
White stuff is anti-gel for wintertime cold temps, and the grey stuff is for summertime, with cetane supplement.
They both lube.
Old May 16, 2008 | 12:36 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Yep.. ^^^^^^what she said.
Lisa, you beat everyone on this one.
Ron Chichelli
Should I use 2 cycle oil with this or not?
Old May 16, 2008 | 12:38 PM
miller_feed
I don't. Maybe some do.
Old May 16, 2008 | 01:22 PM
03_PSD's Avatar
03_PSD
i use 2 cycle and grey bottle. don't know about benifits from it but does run good and smoother with the 2 cycle. my .02
Old May 16, 2008 | 01:55 PM
miller_feed
How much of each per gal do you use?
Old May 16, 2008 | 01:59 PM
03_PSD's Avatar
03_PSD
1 oz. per gallon of 2 cy. and half of the bottle of diesel kleen grey. (think its a 32 oz. bottle)
Old May 16, 2008 | 02:13 PM
miller_feed
I use .5 oz per gal of DK. I may start putting 2-oil with it and see what happens. Don't think it will hurt anything.
Thanks
Old May 16, 2008 | 02:18 PM
03_PSD's Avatar
03_PSD
hopefully it don't hurt anything, so far only good results.
Old May 16, 2008 | 04:00 PM
rbaker6336's Avatar
rbaker6336
I am trying a mixture of DK and two cycle oil
8 oz DK with 24 oz oil and added to 38 gal of fuel
Old May 16, 2008 | 04:09 PM
piotrsko's Avatar
piotrsko
I run 2 stroke oil with the white in winter, makes injectors quieter, dont run it with grey bottle since they really quiet down with it.
Old May 16, 2008 | 04:16 PM
fbilly420's Avatar
fbilly420
I use 1 quart 2 stroke oil with every tank and my truck has never ran smoother. I used to run the DK grey bottle but I can get 2 stroke oil free. My .02
Old May 17, 2008 | 10:58 AM
Ron Chichelli
Thanks for the help.
Old May 17, 2008 | 11:40 AM
aklim's Avatar
aklim
Straight diesel will be fine. You don't see diesel trucks lined up at the repair shop for 2 miles do you? Most of this stuff is snake oil anyhow. The few that aren't haven't proven to do much except drain your wallet and make you carry about that stuff in a can that might leak. Not worth the time. So far I haven't gotten any better mileage consistently.
