Extra Over-drive gear
Old Oct 15, 2006 | 08:34 PM
DTR's Avatar
DTR
Looking for a little help. I have a 2004 Ford F-350 Super-Duty, 6.0. I was told that there is a set-up that you put on between the torque converter and the drive shaft, that gives an extra gear. From what I have heard, it is electronic, and you can engage the extra over-drive by a push button when you want to. Has anyone heard about this or know anything about it? A name of the product?
Thanks,
Jamie
Old Oct 15, 2006 | 08:37 PM
havi's Avatar
havi
I'll have the Roast Duck
gear vendors od...spendy though.
Old Oct 15, 2006 | 09:47 PM
DTR's Avatar
DTR
Do you know when the double overdrive is engaged, how many RPMs the motor will drop?
Here is my senerio: I pull a 40' enclosed race car trailer. When traveling down interstate at 75 mph, my RPMs are around the 2200 RPM range. However, if I can drop my RPMs to around 1750 RPMs, I can gain 5-6 MPG. The problem with running at 1750 is that it is only about 50 MPH. I am thinking if I could add another overdrive to drop my RPMs 500-600 RPMs, my fuel mileage would increase. I thought about gears, but then I would have to replace both the front and rear gears. Also, a gear change to a higher ratio would make my pick-up more sluggish from a stop. I don't want to give up my take off.
I would appreciate anyones input and expertise.
DTR
Old Oct 15, 2006 | 09:54 PM
havi's Avatar
havi
do you have a zf6speed? they were available in f350's, but that would be 2 granny gears? short of a gear vendors unit, I don't know
jamie1964
Apr 28, 2010 03:12 PM
TheBigF
1997 - 2003 F150
Apr 20, 2010 04:46 PM
hoyt0119
Feb 13, 2009 04:33 PM
jamies460
Jun 24, 2007 10:39 AM
Steelbass
Apr 30, 2004 06:39 PM
