Fan clutch
Old Oct 15, 2006 | 07:42 PM
Jack-Iowa's Avatar
Jack-Iowa
Fan clutch
Hello
I have to replace my waterpump and cannot get the fan clutch off. any tips or clues?
have the special tools but the holder does not seem to want to hold is there a special place or way to hook it up?
They day it is a left thread nut but th ething eill not budge.
1991 F3500 with the 7.3 diesel.
Any help or links or how to greatly appreciated as have to get the truck running.
thanks
jack
Old Oct 15, 2006 | 08:13 PM
pabs's Avatar
pabs
Wink
hey hope this will help.Ive worked on lots of those you have to strike the tool thats on the fan with a hammer hard.
try that always worked for me.
Left hand thread correct.
pabs
Old Oct 15, 2006 | 08:17 PM
bc6.9's Avatar
bc6.9
If you wedge something [wood so not damage anything] between the fan belt pulleys...this always worked for me, lol.
Old Oct 15, 2006 | 08:49 PM
bilder12's Avatar
bilder12
keep the belts on and like bc stated, a piece of wood between the belt and pulley will keep things from turning and LEFT hand thread is correctamundo ... large wrench on fan clutch nut and snap it toward drivers front wheel
Old Oct 15, 2006 | 08:57 PM
dieself250's Avatar
dieself250
heat it up a bit and use a big hammer and since the water pump is being replaced it would be best to replace the cluch
Old Oct 15, 2006 | 09:25 PM
dreadhed's Avatar
dreadhed
Two weeks ago I had to replace my water pump too. I heated mine up with a propane torch. Rember lock tight when you put it back on. I read on here some people put it on with out it and it came off & flew in to the raditor. I didn't have any special tools. I used a skinny pipe wrench & a box end wrench on one of the bolts on the clutch. I also just took the front end off(grill etc etc) & that made it alot easier. That is what worked for me.
Old Oct 15, 2006 | 09:31 PM
fellro86's Avatar
fellro86
Friend of mine had told me to use an air hammer and chisel to get it moving, but if it was lock tited, it wil need to be heated most likely to release it.
BTW, welcome to FTE! If you have some time, scroll down the page and give us a visit in the Iowa chapter...
Old Oct 16, 2006 | 08:43 AM
Jack-Iowa's Avatar
Jack-Iowa
thanks for all the info and the welcome.If I knew what I was getting into I would of took it to an auto shop haha
thanks again
jack
Old Oct 16, 2006 | 07:00 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Jack-Iowa,
Welcome to FTE and the IDI diesel forum.
Do pay close attention to which holes which bolts come out of. They need to go back in the same place to keep from getting a longer bolt against the timing gears.
Also the bolts that end in the center of the timing gear cover need thread sealant on them.
fordka
Sep 17, 2015 01:44 PM
USMC0351fordtruckin
Jun 7, 2013 09:09 PM
True-n-Blue Oval
Feb 26, 2009 06:58 PM
95bogginbronco
Jan 30, 2006 08:52 PM
texan66truck
Jan 18, 2004 12:10 PM
