Timing Question
Old Oct 14, 2006 | 10:45 PM
2tone73's Avatar
2tone73
Unhappy Timing Question
When I set timing on my 360 I usually remove the hose that goes from the distributor to the water neck. Now I recently noticed when I remove that hose from the water neck it does not change the idle. It used to change the idle when disconnected. What can cause this? I can't seem to get the timing right. Its a 73 f250 360 c6 2wd 2bbl. I haven't changed anything recently. Thank You!
Old Oct 14, 2006 | 11:29 PM
Putt's Avatar
Putt
That hose goes to a ported vacuum switch that is temperature controlled. It is supposed to send manifold vacuum to the vacuum advance when cold and then route ported vacuum when the engine is warm. It may be that the PVS has gone bad, but that kinda disagrees with your observations. Are you sure the hoses are hooked up correctly?
GB SISSON
May 30, 2013 08:57 PM
Ivorytooth
13
Jan 19, 2006 08:22 PM
mbrestel
3.8 & 4.2L V6
Jul 13, 2005 04:26 PM
wmodon
Aug 16, 2004 07:50 PM
charlesecarter
17
Jan 8, 2004 03:15 AM
