75 F-250 Overheating
Old Jan 16, 2006 | 06:27 PM
Ivorytooth's Avatar
Ivorytooth
Hi,
This is my first post. I own a 75 F-250 4x4 with a 360 in it. I have very recently replaced the radiator because the old one was coming apart. When I installed it and got everything ready, the engine overheated. I thought maybe the thermostat was stuck, I took it out and tested it. It was fine. The truck doesn't overheat at idle, but I only have to go about 2 miles in it and it overheats.
The top hose is very swollen and under pressure at this time. My only guess is that the water pump isn't working. I can't tell, it isn't making any noise. The last time a water pump went out on me in my mustang, I could easily tell. Which direction does the water flow through the radiator? Does it go from top out the bottom hose? I am not sure. Everything has been checked and replaced except the pump.
Anyone here know what it could be?
Old Jan 16, 2006 | 07:27 PM
Mil1ion's Avatar
Mil1ion
Sometimes this happens when you replace rads.
You need to burp the air out of the system.
Run it up to operating temp with the rad cap off and let the water burp out and keep filling it back up.
Once it stops burping,drain some of the water out then add the necessary coolant.
Old Jan 16, 2006 | 10:00 PM
timothy47129's Avatar
timothy47129
Have you rplaced the radiator cap?It has a lot to do with it
Tim
Old Jan 16, 2006 | 10:36 PM
Ivorytooth's Avatar
Ivorytooth
Thanks!! That makes sense, I thought I burped it enough, but didn't let it run with the cap off very long.
Thanks both of you for your help!!
Old Jan 16, 2006 | 11:16 PM
Bdox's Avatar
Bdox
Originally Posted by Ivorytooth
Hi,
If the top hose is "very swollen" it may be weak due to age.
The coolant is drawn into the water pump from the bottom of the radiator (after it is cooled,) pumped through the block and heads then out through the upper hose to the radiator again.
If you find there is no air in the system, it may be that your lower hose collapses when you are driving, restricting the flow. The pump intake creates a negative pressure. (It sucks.)
Replace both radiator hoses.
Old Jan 17, 2006 | 02:42 AM
Ivorytooth's Avatar
Ivorytooth
Thanks, that is helpful to know. I think it is air. The hose can't collapse with the inserts on them. There a lot of pressure in the top hose, I think the burping will help. I have never swapped a radiator before.
Thanks for telling me the flow. I wondered about that. Never thought of it unitl now. That makes alot of sense and is a good thing to troubleshoot. Thanks!!
Old Jan 17, 2006 | 02:50 AM
ford390gashog's Avatar
ford390gashog
you made sure to replace the t stat and cap right? installed the t stat the correct way?
Old Jan 17, 2006 | 11:05 AM
Mil1ion's Avatar
Mil1ion
Let's hope he bench tested the thermostat at least, even a new one needs testing
Old Jan 17, 2006 | 12:51 PM
Ivorytooth's Avatar
Ivorytooth
I did do those things. The new stat didn't work too well, but the old one did so I put it back in and yes, the correct way. I am not the most gung ho mechanic, but I have done some.
I will burp it today and let you know if that worked.
Bdox's Avatar
Bdox
Well he did say that it doesn't overheat at idle.
Old Jan 17, 2006 | 03:48 PM
T18skyguy's Avatar
T18skyguy
On some of the lower hoses they will have a coiled spring inside. This prevents them from sucking shut and blocking the coolant flow. In the past I have reused the spring in a new hose if it didnt come with one.
Old Jan 17, 2006 | 08:10 PM
timothy47129
I have never found a new hose with a new spring in it.Is that only with the extremly over priced hoses?
Tim
Old Jan 17, 2006 | 09:56 PM
Bdox's Avatar
Bdox
Not necessarily. Newer hoses are more resistant to collapse. But they do often soften up with age.
Old Jan 19, 2006 | 08:22 PM
Ivorytooth's Avatar
Ivorytooth
Just to let you all know, the burping was the solution. Of course by the time I went to burp it, most of the air was gone because of the overheating episodes and me bleeding off the air from the cap.
Thanks again!! I didn't realise that much air would get trapped in a new radiator.
MoJensen87
Mar 6, 2014 02:47 PM
supawah
Jun 9, 2013 09:22 PM
code_red_beast
27
Feb 25, 2013 11:39 AM
Compujedi
1997 - 2003 F150
35
Oct 9, 2008 10:42 AM
texasguitar903
1997 - 2003 F150
May 22, 2008 03:32 PM
