3.0 trouble
Old Oct 14, 2006 | 02:46 PM
pyerby's Avatar
pyerby
3.0 trouble
i have a 94 Ranger 3.0 4x4. when i changed my oil, it was at the right level. now the level is way above the DO NOT OVERFILL line on the dipstick. i dont know what is in it but its bothering me. does anyone know what it could be? it also smokes blue out of the exhaust on startup and sometimes while driving. could it be a leaky injector? please help.
Old Oct 14, 2006 | 03:19 PM
thefonz#1's Avatar
thefonz#1
If it is fuel you should be able to smell the dip stick and smell gas. How is you water level? Also if your oil level is way above the full mark, drain some out. Don't run it with excess oil level.
Old Oct 14, 2006 | 03:27 PM
pyerby's Avatar
pyerby
well ive smelled it and i can smell something but i dont know exactly if it is gas or not. i think it is. do you have an idea of what it could be? water level has stayed the same.
Old Oct 14, 2006 | 03:46 PM
pawpaw's Avatar
pawpaw
Do a fuel pressure test & see if it'll hold pressure after the fuel pump has shut off.
If the pressure is ok, but dropps off right after the pump shuts off, it's likely you have one or more injectors leaking down.
If so, what you have now is fuel diluted lubricant in the oil pan, so if you remove anything from the pan, you'll be down on lubricant volume & still have diluted oil in the pan & filter.
SO, imo, if it's indeed fuel dilution, you should drain the sump & replace the oil filter & fix the problem. Driving the vehicle, with fuel diluted lubricant, will likely do damage to the engine.
Old Oct 14, 2006 | 04:18 PM
thefonz#1's Avatar
thefonz#1
Good job pawpaw, I should have said what you did about the complete drain and change. Pyerby, are you positive the oil level was correct after the oil change? Checked with the dipstick?
Some oil pans have two drain plugs. My brother did this on one of his vehicles, then just added 5 qts. and figured it was good, and ended up being way over full.(Not challenging your knowledge or ability but we don't know what your experience or knowledge is.)
Old Oct 14, 2006 | 05:12 PM
pyerby's Avatar
pyerby
i only have one drain plug and i checked it with the dipstick several times after i changed it....always do. but i had thought it was a leaking injector. i think i will change them anyway....cant hurt i guess. thanks yall.ill try and then see what happens.
Old Oct 14, 2006 | 05:18 PM
pawpaw's Avatar
pawpaw
Seems to me. if you have a bad injector leak down problem, you'd also be having some driveability & fuel consumption problems too
Old Oct 15, 2006 | 07:33 AM
wendell borror's Avatar
wendell borror
Most common problem would be blown head gasket, water in oil, or antifreeze, whatever, it causes blue smoke as well. It does happen from time to time on the 3.0's. I have never had a 3.0, but just from reading the forums, the head gasket issue does come up on the 3.0's enough that it would be one of the first things I would check.
Old Oct 15, 2006 | 05:44 PM
pyerby's Avatar
pyerby
i do get bad gas mileage for a V6. Its like 16 17 mpg
Old Oct 15, 2006 | 06:07 PM
Dave257's Avatar
Dave257
Blue smoke is burning oil, black is a rich condition. You are blue so its oil your burning. If its "Way Above" the overfill line it just sounds like you have too much oil in it, drain it back to the correct level. Fuel mileage sounds about right for 3.0l 4x4.
Dave
DieselDreamer
Modular V10 (6.8l)
16
Feb 17, 2012 04:22 PM
sctrailrider
Aerostar
Oct 12, 2006 02:34 AM
JeremyJ
Oct 3, 2006 05:45 AM
HaroldCallahan
Jul 1, 2006 10:26 PM
my82gt
Aerostar
Nov 29, 2004 08:38 AM
