Sponsored by: Real Truck
bed height
Old Oct 13, 2006 | 10:29 PM
h20boy's Avatar
h20boy
bed height
I just traded my 01 F250 V10 for an 04, and was looking at the 04 from the back and noticed that one side of the truck looked a little lower than the other.
I got a tape measure, and measured at the top of the rear wheel well lip, the left side is ~1/2 inch lower than the right. The front fenders are the same height.
Anyone have any experience with this? Can this be fixed? It looks like the bed bolts directly onto the frame, so without torsion bars it looks to me like shims are the only thing to be done.
Anyone?
Old Oct 13, 2006 | 11:50 PM
blackhat620's Avatar
blackhat620
h20boy,
Fairly common, as the fuel tank is on the left side, more weight equal a little more sag on that side. I believe a 1/2 - inch is within spec. Tech folder is down currently so i can't verify the number for you.
Hope this helps
Old Oct 14, 2006 | 12:34 AM
blackhat620
h20boy,
Found it.
"99-05 F-SuperDuty Rear Suspension Lean:
This applies to rear suspension lean only. The truck needs to be parked on a level surface with no load (or at least loaded evenly) and all tires inflated evenly. Inspect for spring damage or shackle bushing wear. Measure vertically from the lowest point of the wheel rim (not from the ground) to the wheel lip. If the measurment is within 3/5" from side to side, no action is required. If the measurement is greater than 3/4", measure the gap from the top of the axle to the rebound bumper bracket. If this measurment is within 3/4", inspect the body mounts and have the frame checked. If the measurement is between 3/4-1", install shim 3C3Z-5A300-AA on the low side, between the spring spacer and spring seat. If the measurement is between 1-1.75", install shim 5C3Z-5742-AA on the low side. If the measurement is greater than 2", replace the spring. Install longer U-bolts if necessary.
TSB 04-23-6"
Hope this helps
Whirnot
Nov 26, 2014 02:12 PM
brider
Mar 9, 2013 06:49 PM
brider
Mar 9, 2013 06:43 PM
1bosshog2
Feb 3, 2011 09:24 AM
BURNSTOUGHFORD
1997 - 2003 F150
Jun 23, 2007 01:57 PM
