10 degree btdc?
Old Oct 13, 2006 | 10:10 PM
jr27's Avatar
jr27
10 degree btdc?
This is located to the LEFT of TDC for an 89 5.0 EFI, correct? Also, the VECI sticker has been painted over so I'd like to make sure that 10 degrees BTDC is the correct setting for my engine.
Thanks.
Old Oct 13, 2006 | 11:50 PM
EPNCSU2006's Avatar
EPNCSU2006
The engine rotates counterclockwise when looking at the front of the truck, so 10° btdc is actually to the right of tdc mark if you are looking down on the damper with the marks facing up. 10 degrees is the correct setting for the 5.0, you are correct.
Old Oct 14, 2006 | 12:24 AM
Flatlanded87's Avatar
Flatlanded87
Just a tip...
Make sure your SPOUT is disconnected... I had one HELL of a time timing my truck due to me being stubborn, and not looking at the book! I figured once a 302, always a 302... i was wrong to say the least
Old Oct 14, 2006 | 07:14 AM
jr27's Avatar
jr27
Yeah, I timed the truck yesterday without disconnecting the SPOUT. Took it for a test drive and I was blowing white smoke several times. It isn't the exhaust system since I had all of that replaced when I first got the truck back in April. I'll time it again today, but this time disconnect the SPOUT, and see what happens. Thanks.
Old Oct 14, 2006 | 12:05 PM
jr27's Avatar
jr27
Timed the truck with the SPOUT wires disconnected. Runs a lot better now. There still seems to be quite a bit of white exhaust, though. Doesn't seem to be too much of a problem if I put the truck in overdrive. Could be the oxygen sensor but that's just a shot in the dark.
Old Oct 14, 2006 | 12:12 PM
pwcharlie's Avatar
pwcharlie
Are you sure that white smoke isnt steam caused by a coolant leak into the combustion chamber. Are you having to top off your coolant level more then usual?
Old Oct 14, 2006 | 12:35 PM
jr27's Avatar
jr27
It could be steam. I've only had the truck running for two days now, haven't been able to check the coolant level reliably yet. It started doing this after I hauled a 5x8 trailer 6 to 8 hours from Atlanta to Pensacola a few weeks ago, but that was with a load. I'll keep an eye on the coolant level to be sure.
topfile
Aug 12, 2012 10:33 PM
Pop's76
Feb 18, 2011 05:27 PM
Drac
Feb 1, 2008 10:19 AM
Eddie
Oct 31, 2001 01:11 PM
unioncreek
Jul 23, 2001 05:34 PM
