360 Timing
Old Jul 17, 2001 | 03:58 PM
unioncreek's Avatar
unioncreek
360 Timing
On my 360 it has the timing at 6 degrees BTDC, in drive at 550 RPM. I seen in a few of the older posts that the 360 will run better at 10 degrees. Is this correct?
Thanks,
Bob
Old Jul 17, 2001 | 06:13 PM
390fe's Avatar
390fe
360 Timing
Try it and find out! :-) Some engines run better, some don't.
Jason Kendrick
1970 F100 Custom 390/C6
1978 F150 Ranger Lariat Supercab 460/C6
Old Jul 18, 2001 | 10:27 AM
buzzard's Avatar
buzzard
360 Timing
The spec for the 390 is 10 degrees and it is virtually the same engine aside from it having a little higher compression with a different stroke.
Old Jul 18, 2001 | 06:51 PM
greghoffmann's Avatar
greghoffmann
360 Timing
I have been messing with the timing on my 360 and it runs the best at 12% btc.
1971 F-350 1 ton dump, ground up fully restored w/ 360 motor
Old Jul 23, 2001 | 01:34 PM
ALC's Avatar
ALC
360 Timing
I just finished timing my 360 yesterday and about 12 degrees BTC is about right...the book calls for 6 degrees for standard and 10 degrees for automatic
Old Jul 23, 2001 | 05:34 PM
jowilker's Avatar
jowilker
360 Timing
Redonkulous BOB
Dec 21, 2011 10:18 PM
WhiskeyRider
Jan 31, 2010 08:38 PM
ranger086
1983 - 2012 Ranger & B-Series
Nov 17, 2007 09:36 AM
bob arrington
Dec 17, 2003 08:55 PM
bob arrington
19
Dec 10, 2003 08:01 PM
