ignition removal
Old Oct 13, 2006 | 10:02 AM
kaduh's Avatar
kaduh
ignition removal
Hey everyone;
I need your help. I have a 1996 F-150 that I wrecked, so I found one on ebay that I bought for parts but it is a Katrina flood victim and the salvage yard doesn't have the key. I need to take the Ignition out of the steering column in my truck here in Houston and put it into the one I bought over in Louisiana in order to get it on the trailer. Any help will be appreciated.
Thanks,
Brian
Old Oct 13, 2006 | 10:43 AM
quicklook2's Avatar
quicklook2
turn your truck's key to run
use 1/8" drill in hole under the lock to disengage button
pull out cylinder
Old Oct 13, 2006 | 10:47 AM
kaduh's Avatar
kaduh
Wow! It's that easy? Thanks so much. I'll give it a try.
Old Oct 13, 2006 | 12:35 PM
Leader's Avatar
Leader
DO NOT remove the key from the lock while it is out.
Have you thought about how you are going to get the one in LA. out ?
If they can get that one out, the can unlock the stearing and you won't need your ignition.
Old Oct 13, 2006 | 01:33 PM
kaduh's Avatar
kaduh
No I didn't think about the one in LA. until I was on my way back home from removing the ignition... I may be screwed. Is there any way to get that one out without breaking the column?
Old Oct 13, 2006 | 03:51 PM
quicklook2's Avatar
quicklook2
leader, i wanted him to figure that out when he had time to think about it.
i posted before how ford manual says to do if key broke off or lost keys to get cylinder out. here it is again:
-disconnect battery ground cable.
-remove steering wheel.
-using channel lock pliers or vise grips, twist lock cylinder cap until it seperates from the lock cylinder.
-using a 3/8" diameter drill, drill down middle of ignition key slot approx. 44mm (1-3/4") until lock cylinder breaks loose from breakaway base of lock cylinder. remove lock cyl. and drill shavings from the lock cylinder housing.
DO NOT DRILL TO DEEP!
-remove retainer, washer, ignition switch and actuator. thoroughly clean drill shavings and all other foreign materials from casting.
-carefully inspect lock cyl. housing for damage from the above operation. if damage is apparent, housing must be replaced.
install your lock cylinder.
good luck!
Old Oct 13, 2006 | 04:39 PM
kaduh's Avatar
kaduh
Thanks Quicklook2. I've lost critical thinking powers throughout this process! I'll let you know how it turns out.
Once again, thanks to all of you for your help.
Brian
Justin Doe
Jan 28, 2015 07:22 PM
75Three90
Dec 19, 2014 09:57 AM
G-Diesel
All Things Towing
Mar 6, 2014 01:55 PM
35w
Dec 3, 2012 01:43 PM
Chasjr1
Modular V8 (4.6L, 5.4L)
Mar 19, 2008 10:31 PM
