Gear ratio 9" Ford
Oct 12, 2006 | 09:07 PM
Gear ratio 9" Ford
I'm curious what the gearing of choice of everyone in here is?. I have a 9" ford and am running 3.50 gears.
Oct 12, 2006 | 09:38 PM
I have 3.70 but also double overdrive 0.50 6th.
Oct 12, 2006 | 11:22 PM
I'm running 3.50 gears in my 9" as well.
Oct 12, 2006 | 11:40 PM
I'm running 3.50 as well.
Oct 12, 2006 | 11:57 PM
53 and Randy- Do you guys have overdrive? and what are you taching on the freeway. I'm taching about 2500 @60 miles per hour. Thanks guys.
Oct 13, 2006 | 03:18 AM
The original 3.70 that came w/ the original 9".
Oct 13, 2006 | 06:37 AM
Ed,
Swapped from a 3.50 to a 3.00
Oct 13, 2006 | 07:05 AM
Mine is 3:50 also. I do have a AOD trans but my speedo is off a lot (replacing it this winter with a elect speedo and cruise control).
When I drive on the Eway and keep up with traffic in the right lane it's running at 2000 rpm. I'm guessing thats somewhere near 70+ mph
Chuck
Oct 13, 2006 | 07:07 AM
I have a 4.30 posi in mine.
Oct 13, 2006 | 07:49 AM
Not back on the road but I have a 3.70 with a .67 AOD.
Oct 13, 2006 | 08:11 AM
Ok, I just checked it out on one of these on line calculator programs and the results are, 27.8 tire (P23/70R15), 3:50 final drive ratio and a .67 trans ratio @ 2000 rpm I'm traveling at 70.57 mph.
Chuck
Oct 13, 2006 | 08:54 AM
Ed -
I don't ever travel at 60 mph. But I tach 3200 at 70!
I plan on an AOD someday, to improve mileage. But I sure like the grunt I get off the line from that 3.50 posi!
Oct 13, 2006 | 10:38 AM
I changed out my 3.50s to 3.00s thanks to Daryl and Butch. Nice cruising rpms. Jag
Oct 13, 2006 | 11:28 AM
In 6th @ 2000 RPM I'm doing a even 90 MPH! It's just at a high idle @ 70. Don't even need to put my foot on the pedal @ 55!
Oct 13, 2006 | 11:53 AM
I sure will be glad when I get mine out on the highway to find out what my cruzin' RPM will be. I'm running a very tall rear gear (2:26) and 225/75 R15s but no OD transmission. My guess is somewhere around 1800-2000 RPM at 70.
