fuel leak help
Old Oct 11, 2006 | 06:37 PM
str400ex's Avatar
str400ex
fuel leak help
I just found a leak just to the left and behind of the turbo I belive its some kind of fuel pump or injector pump not sure I have not had a chance to dig into it yet any help would be great, where can I get a repair manuel for my 97 powerstroke thanks Shawn Reardon
Old Oct 11, 2006 | 07:17 PM
trike1946's Avatar
trike1946
The pump is in the valley. It could be that, or the hoses, maybe a loose cap on the filter, or the lines to the heads from the pump. You are going to have to get a good look at it to tell. Are you sure it is fuel and not engine oil?
I got my repair manual from Pep Boys. It is for diesel engines. You need another for the truck. Probably our sponsors have manuals. Check them out.
Old Oct 11, 2006 | 08:25 PM
str400ex's Avatar
str400ex
fuel
its fuel it only leaks when the trucks running
Old Oct 11, 2006 | 08:34 PM
trike1946's Avatar
trike1946
The fuel pump has a small hole near the bottom on the passenger side where it leaks when it is going bad. Hard to see.
UGA33
Mar 15, 2017 09:56 PM
Larryd8563
Oct 17, 2014 02:50 PM
95schauf
Jan 8, 2012 12:50 AM
ftowelding
18
Apr 4, 2008 07:43 PM
FarmallFan
Sep 11, 2002 10:19 PM
