Rubber fuel lines
Old Aug 27, 2002 | 12:44 PM
FarmallFan's Avatar
FarmallFan
Rubber fuel lines
My '67 is giving me fits with it fuel system. I just got the transmission reinstalled, and the engine would not fire. Found the pump was not getting fuel to the carb. So I replaced the pump. Ran for a while, then died again, no fuel to the carb. So I suspect the fuel line between the pump and tank is leaking so the pump cannot pull fuel. Can I just run rubber fuel line from the tank to the pump or should I use metal? Thanks!
Old Aug 28, 2002 | 01:56 PM
gasman6674's Avatar
gasman6674
Rubber fuel lines
My .02 I would run metal tubing as much as possible then rubber for flexability
Regards
Gasman
Old Aug 28, 2002 | 04:50 PM
beartracks's Avatar
beartracks
Rubber fuel lines
If you use rubber make sure it's stiff enough that it doesn't collapse under suction.
Old Aug 30, 2002 | 04:17 AM
Torque1st's Avatar
Torque1st
Posting Legend
Rubber fuel lines
Try to find the leak or blockage and repair it if possible.
Rust can eat thru a fuel line but it will usually show up as a fuel leak also.
Rubber lines will crack or rot out, that will usually show up as a fuel leak also.
Run a wire thru a steel line or use compressed air to check for a blockage.
Replace your rubber lines if they are old anyway.
Old Aug 30, 2002 | 01:06 PM
Vampiro's Avatar
Vampiro
Rubber fuel lines
keep the metal lines as much as possible. gas will errode ruber after a while
Old Sep 5, 2002 | 11:31 AM
beartracks's Avatar
beartracks
Rubber fuel lines
If you have crack or loose connection on the tank side of the pump you will suck air instead of fuel.
Old Sep 11, 2002 | 08:45 PM
jds1971's Avatar
jds1971
Rubber fuel lines
Rubber from the pump to the carb will trap heat and cause the fuel to boil by the time it reaches the carb. That has been my experience. Stick to a metal line. I use 5/16 brake line. It ought to last another 30+ years and you will have gotten your money's worth for sure.
Joe
Old Sep 11, 2002 | 10:19 PM
otto's Avatar
otto
Rubber fuel lines
1984montemaniac
Apr 28, 2017 07:53 AM
SteveH123
17
Sep 5, 2016 12:51 PM
brk300
May 1, 2016 08:37 PM
RTennant71
16
Jun 13, 2011 10:06 AM
Wicked Endings
13
Feb 9, 2011 07:04 PM
