Fuel Pump replacment
Old Oct 11, 2006 | 10:17 AM
mbuck54's Avatar
mbuck54
Angry Fuel Pump replacment
I have 1997 4.0 Ranger, the fuel pump went out last night. Is there one or two pumps. How much does it cost to have this repaired. How hard is it to do yourself. I would appriciate any input from somone who has done this before. Thanks.
Old Oct 11, 2006 | 04:01 PM
Rockledge's Avatar
Rockledge
One pump on your '97.
THIS THREAD may help you.
Old Oct 11, 2006 | 05:54 PM
pawpaw's Avatar
pawpaw
You didn't say how you've determined the pump is kaput, so first, make sure your fuel pump has given up the ghost.
Common problems that mimic a pump failure are, blown fuel pump relay fuse, bad fuel pump relay, tripped, or bad fuel pump inertia cutoff switch, located in the passenger side cabin foot well, just above the carpet, about where your right foot is placed, or behind the passenger side kick panel.
So try pushing the red reset button on the inertia switch, just in case you've been bumped in a parking lot, or a passenger with a size 11 shoe hasn't kicked & tripped it!!!! lol
If you've checked all those common things & have determined the pump really is bad, then I agree, pulling the bed back, to access the pump, is easier than emptying & dropping the fuel tank, to replace the pump.
Not certain of the actual cost nowdays for a fuel pump for a 97, guess it would depnd if it's a OEM Motorcraft, or aftermarket, but I'll bet you could price one online at most any autoparts supplier.
Just some ideas to ponder.
Let us know how it goes.
