1966 Ford brake light switch (need help)
Old Jun 15, 1999 | 03:18 PM
Peter Brusa
Guest
Posts: n/a
I have a Twin-I-Beam '66 and need to locate the brake light switch. I *think* I have located it (next to brake reservoir on fire wall), but need to verify this with someone.
Also, does anyone know where to order a new/used switch (pref new).
You can email me privately as well.
Thanks in advance.
-Peter Brusa
Kennesaw, GA
66 Ford
95 Miata
Old Jun 15, 1999 | 06:25 PM
jowilker's Avatar
jowilker
Peter you are absolutely on the bubble. That twin I-Beam 1966 Ford F100 has the brake light switch right there beside the single line master cylinder on the firewall.
You can get a new switch at your favorite parts house.
Why do you want to buy a new one, have you tested the two wires connected to the switch to see if there is power. I think one is hot all the time, and when the pedal is depressed the other will be hot, to light the rear bulbs. Check that first before you purchase a new one
Old Jun 16, 1999 | 11:17 AM
Peter Brusa
Guest
Posts: n/a
Thanks for the info! I will check this out. The lights come on with the headlights, but do not illuminate the second filliment.
My first guess was the switch...I'll also check the wiring and ground as well.
I am shocked that my local parts store may carry something like this, especially for a '66!
Thanks again!
-Peter Brusa
1966 Ford
1995 Miata
Old Jun 17, 1999 | 02:07 PM
jason's Avatar
jason
Have you tried your local parts store yet? You should find one there for not much cash.
Old Jun 18, 1999 | 12:37 PM
Dan64F100's Avatar
Dan64F100
Old Oct 7, 2012 | 12:01 PM
jimmielee's Avatar
jimmielee
Need the brakelight switch also
Can't find it on line at OReillys and other online sights show a pedal switch which isn't what we need. Could someone let me know where to get one? LMC catalogue doesn't show one either
Old Oct 7, 2012 | 12:18 PM
davewave649's Avatar
davewave649
Sorry Double Post
Old Oct 7, 2012 | 12:20 PM
davewave649
Autozone carries them just might have to go into the store and have them get it as opposed to looking online before hand
Old Oct 7, 2012 | 12:28 PM
66f-100's Avatar
66f-100
Autozone has it for $6
Duralast/Stoplight Switch (F4805) | AutoZone.com
Old Oct 7, 2012 | 06:46 PM
jimmielee's Avatar
jimmielee
Thanks I got one
I live in the boonies and 10 miles to the nearest store but I got one, Thanks again.
Old Oct 12, 2012 | 10:00 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C1AZ-13480-A (replaced 01A-13480) .. Brake Lamp Switch (Motorcraft SW-24) / Available from Ford and a gazillion autoparts stores.
Applications: 1940/66 most FoMoCo vehicles / Same as Studebaker #666858 ~ 1950/66 all and 1951/54 Packard, 1955/56 Clipper without Torsion Bar suspension, 1957/58 Packabaker.
Next time y'all need one a these puppies, ask for it for a 1965/66 Mustang, it's the same.
4inchlovin
May 22, 2014 10:27 PM
PeeVee
1947 and Older Ford Trucks
Oct 12, 2009 08:39 PM
Peterand
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jun 18, 2009 11:10 PM
workingdog
Jan 7, 2008 06:43 AM
