losing power
Old Oct 10, 2006 | 08:44 PM
swampthing47's Avatar
swampthing47
Unhappy losing power
I have a 1995 F150 4x4 302 pickup ,it runs great when gas tank is full but seems to lose power after gas gets below half a tank , is this an indication that the fuel pump is going bad or something else?
Old Oct 10, 2006 | 08:48 PM
quicklook2's Avatar
quicklook2
it could be but it could also be a bad fuel filter.
describe your truck a little more, mileage, when last tuned up, etc.
Old Oct 10, 2006 | 08:56 PM
swampthing47
recently tuned up , I replaced the fuel filter, spark plugs ,cap, rotor and plug wires all
with oem parts. plan on changing coil soon.
Old Oct 10, 2006 | 09:37 PM
quicklook2's Avatar
quicklook2
the plug wires need to be routed a certain way so they do not arc.
did you do this?
Old Oct 11, 2006 | 10:06 AM
Kemicalburns's Avatar
Kemicalburns
check fuel pressure at the rail at idle and while driving this will indicate an issue if there is one
Old Oct 19, 2006 | 03:14 PM
PerfDistIgnition's Avatar
PerfDistIgnition
FTE Sponsor
Although we would like to see you run our Screamin' Demon Coil, a bad/weak coil is not causing your "below half a tank" loss of power. See:
http://www.performancedistributors.c...50ignition.htm
SCROLL DOWN to see the 5.0 Firepower Kit.
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
Old Oct 19, 2006 | 05:07 PM
Kemicalburns
this is a fuel delivery issue not ignition related. and to honest the ignition on our rigs are more then capable of handling the motors we have under the hood. keeping in tune is the key
Old Oct 20, 2006 | 11:55 PM
PerfDistIgnition
FTE Sponsor
Under Your Hood
I agree this is a fuel problem; however, I must state that even stock motors will benefit from a performance ignition(whether it ours or another reputable ignition mfg.) You are absolutely correct, that keeping in tune is a key, but so are variables such as voltage under load, dwell time, being able to run wider plug gaps, and durability.
__________________
FTE Sponsor
BaronVonAutomatc
Nov 24, 2014 05:53 PM
lbj
Aug 4, 2011 09:02 PM
dr strangelove
Sep 9, 2010 04:13 PM
EvanJ
Mar 26, 2009 01:14 PM
SAUER
Dec 13, 2003 06:06 PM
