3 Speed Manual Conversion to Automatic
Old Aug 6, 1999 | 09:42 AM
dane's Avatar
dane
<center><font size="1" color="#ff0000">LAST EDITED ON Aug-08-99 AT 03:18&nbsp;PM (EST)</font></center>
Old Aug 6, 1999 | 10:35 AM
jowilker's Avatar
jowilker
> Would someone help me with what year models will
interchange without any modification?
NONE
You can't change from straight to auto without modifications.
If you post a better question I'm quite sure that you will get the help that you need.
John
Old Aug 7, 1999 | 08:54 PM
dane's Avatar
dane
<center><font size="1" color="#ff0000">LAST EDITED ON Aug-08-99 AT 03:17&nbsp;PM (EST)</font></center>
Old Aug 8, 1999 | 05:49 AM
jowilker's Avatar
jowilker
If your 65 is a 2X4 you can use any 2X4 through 79 with the 6cyl. engine. You will need the column (take your time with the wires, your flasher is on the dash, some of the later are on the column. I just eleminated the column flasher) linkages shifting and kickdown, as well as carb connections, and the driveshaft. Look for the boot on the donor where the clutch rod goes through thr floor pan, you won't need the hole any longer. Don't forget to remove the pilot bearing, you can break the transmission bell, I did. Just drop the clutch pedal. The spring can be a bugger, but just stick with it, it'll come. There is a good chance that you will have to have the driveshaft modified, so be ready for that. Plan to be without the truck for 3-4 days or longer.
Old Aug 9, 1999 | 05:44 AM
jowilker's Avatar
jowilker
GaryKip
16
Mar 8, 2016 01:12 AM
The Masked Rider
Jan 9, 2016 04:44 PM
hammer65
2009 - 2014 F150
21
May 1, 2015 10:12 AM
willindsay
New Member Introductions
May 19, 2008 07:58 PM
jjz 109
Oct 3, 2007 03:29 PM
