You can purchase a Ford repair CD. I do not know of any links on the web....someone else may have an idea. I'll write up a general description for you if needed.
303-755 is the HPO line quick disconnect tool only for the 2003 models and will be of no use for you; you can change injectors on those trucks without it anyways, simply by removing the rail with the line still attached.
303-625 is for a 7.3 liter Powerstroke, so likewise you won't need it either.
303-1115 is designed to disconnect the electrical connector from the top of the rocker arm carrier; an 18mm socket wiggled back and forth on the top of the connector will do the same thing.
I believe it is a 19mm socket. The large end of a die-grinder wrench can be used to disconnect the oil line from the rail if need be. Make sure that you use a good quality T-40 to remove the injector hold down so as not to break the socket, because any broken metal pieces that fall into the valve train normally ends up in the oil pan before taking a very destructive trip through your high-pressure oil pump.
mine is the early o4 which uses these tools but i did find something similar that worked. Also the socket worked well to remove the electrical connector. The injector had a blown out lower o-ring causing the cylinder to fill with fuel during start-up and would run for a few minutes than flame out then would not even turn over because the cylinder would be full of fuel.
18mm works too; never used a 19mm simply because I always have the 18mm impact socket out to remove head bolts. I would assume that either works.
I like a shallow thin wall 3/8 drive 19mm, especially doing injectors on an Econoline where there is hardly enough room to use the "special" tool...
I normally get my "very gifted" apprentice to do most of my headgasket or engine jobs, so my 18mm stays locked away!
For some reason he likes to do big jobs like that... I think he needs more medication or something. But it all works out well, since we only have 3 diesel techs and enough work for atleast twice as many... and things get pretty messed up if one of us gets on a big job.
