Edge Platinum
Old Oct 9, 2006 | 06:35 PM
moulin's Avatar
moulin
Edge Platinum
The Edge has 5 preprogrammed modes with #2 being the tow mode. The 6.0 has the tow/haul function of the torqueshift. Will there be a problem using the tow (#2 Edge) with the tow/haul function enabled on the torque-shift? If anyone has any experience using the Edge with the torque-shift let me know. I'll be towing an 8k travel trailer on Thurs and want to make sure I don't harm the vehicle. Thanks!
Old Oct 10, 2006 | 06:32 AM
onirot's Avatar
onirot
I have the same programmer, and use the #2 setting with towing all the time. The tow/ haul button is for the transmission to lock the torqe converter longer, to keep things cooler. They serve 2 separate functions, the programmer make more HP, the transmission uses it better.
Old Oct 11, 2006 | 08:56 AM
Quicktoy's Avatar
Quicktoy
i pull a tundra on a flat bed on level 4 no problems and drive daily on level 5. as long as your not punching it and driving like you normally would you get the best mpg and no probs
DieselVol
May 2, 2012 06:22 AM
Daddy Wags
Modular V10 (6.8l)
Jan 11, 2011 10:09 PM
timsfordtruck
Jul 21, 2009 03:43 AM
whalerron
Nov 13, 2005 03:14 PM
Soaphauler
Aug 21, 2005 03:30 PM
