Sponsored by: Auxito
Rough Sound When starting from cold!
Old Oct 8, 2006 | 06:23 PM
Rikster-7700's Avatar
Rikster-7700
Hello, wondering if you could help me? I have a 2003 F150 7700, 5.4L V8 xcab with 64000 miles on the clock. When I start the engine from cold it sounds really rough, almost like a diesel, until it warms up, then it seems to smooth out some. just wondering what could be the cause of this. I have checked all my fluids and everything seems ok. If i start the engine while it is still warm it seems ok, it cranks first time evertime, never cuts out, just sounds like a tractor until it wrms up. I am relatively new to all this so please bear with me if this is a simple or common problem. I am hoping it is something that doesn't cost too much and isn't too hard to rectify! Any help greatly appreciated!
Thank you in advance for your help!
Rik
Old Oct 11, 2006 | 03:26 PM
Rikster-7700
After reading around the forum for a little bit, I was wondering if this could be related to rusted out pins on my headers?? I am at a loss, I just don't want to do any more damage to it if there is something seriously wrong with it!
Thank you for any help!
Rik
Old Oct 11, 2006 | 04:42 PM
LxMan1's Avatar
LxMan1
It's possible, does it actually run rough or just sound bad? As the manifolds heat ans expand, they will quieten down some. Could also have some harmless piston slap as well.
Old Oct 13, 2006 | 05:18 PM
Rikster-7700
It still seems to run ok. is there any way to stop piston slap? how much would it cost to sort out the problem if it is the manifold? there is also a slight ticking when idling when warm. Only really noticable when sat next to a wall, like in a drive through.
Once again thank you for your help!
Rik
Kyler7700
13
Feb 15, 2016 10:41 PM
Kyler7700
1997 - 2003 F150
Jan 8, 2015 08:24 PM
WhiteBeast-05-powers
Nov 9, 2013 12:47 PM
cak7700
Nov 15, 2011 08:33 AM
78 short
1997 - 2003 F150
Jun 17, 2005 12:52 PM
