Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
how does high freq on tig welder work?
Old Oct 8, 2006 | 02:57 PM
karljay's Avatar
karljay
Does the High Freq automatic start sence when you are close to the metal and jump the amps up, or do you press down on the pedal or what? I know the old way was to strike a copper plate, but I've never used this machine and just wondering what to expect.
I do know you're not supposed to touch the tung tip to your work, so what's the trick to this.
Old Oct 8, 2006 | 05:24 PM
200000+F150's Avatar
200000+F150
H.F. is a high-frequency (about 3Mhz ususally) at around 3000 volts. It jumps the arc gap between the tungsten and the work, creating a path for the weld current to jump. It's kinda like a lot of spark plug discharges. It is used to start the arc on DC and to both start and maintain it on AC. (AC, being alternating current, the arc goes out 60 times a second). All you do is position your tungsten over the work, press your foot pedal and let the HF jump. The arc will start and your heat will increase as you press down on the pedal.
jjlanotte
Modular V10 (6.8l)
Oct 6, 2016 10:10 AM
mongo75
Jan 10, 2012 10:37 PM
pete17c
Feb 26, 2010 12:34 PM
RanDawg
Dec 19, 2002 10:34 PM
