Today I was trying to isolate a high freq vibration, so I put her in neutral, and shut it off. When I tried to start it at the bottom the hill I wound up pulling into the break down lane, and after about 5 minutes and 4 long cranking sessions it started finally. What would cause this abnormality?
How did it crank when you had the no start Danny? Fast like the injectors weren't being fired? Any smoke out the tail pipe while cranking? Any stored codes? Can you duplicate the problem or was it a fluke?
Hey guys thanks for responding. It cranks just fine, I have regular (65lbs) fuel pressure, and no smoke, almost like it's not getting fuel. I'm running the black CPS and it does show the 100 rpms when cranking so it is working. It just seems like it's not getting fuel. And I guess you say it's a repeat issue, as I've done it before- doing 65 on the fwy, throw it in nuetral, and shut it off. Last time I did it I had the same problem. I'm stumped!!
