Impossible to change fuel filter.
Old Oct 7, 2006 | 05:48 PM
Krochus's Avatar
Krochus
Did the fuel system engeneers at ford in the late 80's early 90's just not care? Why in the heck didn't they place the fuel filter 8" further down the frame rail from the tanks rather than hiding the infernal thing behind the front tank. And to add insult to injury they used the most retarded line fastners mankind has yet devised
I've already gone through 3 line tools and have yet to get even one end of the fuel filter loose. My truck has the original 150K mile fuel filter on it and it's starting to run like crap. I guess I'm supposed to junk the truck when the fuel filter finally stops up.
Does anybody have any suggestions short of getting thehacksaw out?
Old Oct 7, 2006 | 09:04 PM
Cheggie's Avatar
Cheggie
A little W-D40, push and twist.....breathe......find your chi.....
It will come apart.
Old Oct 7, 2006 | 09:27 PM
quicklook2's Avatar
quicklook2
i break them off so that you can pull the line down to get fitting off. do not hacksaw, just move it back and forth where fitting connects to filter.
Old Oct 7, 2006 | 09:42 PM
Krochus's Avatar
Krochus
I had already used WD-40 and I'm certian it had hepled, But what finally made the diffrence was a pair of white chicken plucker gloves. Once I got good and rough with the fittings the plastic line tool started digging into my fingers. I remembered a pair of knit gloves in the glove box, put em on and was able to get even rougher on the fittings. That made the diffrence
I find that when stuff has to be gotten rough with a pair of gloves really helps.
Old Oct 7, 2006 | 09:53 PM
quicklook2's Avatar
quicklook2
now that wasn't so hard after all.
that first time is a pain, now you will be looking for other f150 filters to change.
use the gloves though.
Old Oct 7, 2006 | 10:20 PM
alabamabuddog's Avatar
alabamabuddog
I have found that if you take the nuts off the back of the filther bracket you have alot more room to work with. And giving it a small twist help alot more.
Old Oct 8, 2006 | 09:38 AM
924x2150's Avatar
924x2150
those small spring-lock connectors on the fuel rails become "seized" after a couple years. I think a very small quantity of fuel gets on the rubber o-rings and dries up, the dried fuel acts like a glue. I had the same problem when I changed my engine a few years ago, the lines going to the engine fuel rail were even harder to break free than the filter connections. Maybe because they are near the engine and the heat helps cook the dried fuel around the o-rings into a harder "glue".
Old Oct 9, 2006 | 12:08 AM
Talyn's Avatar
Talyn
91 and newer were differnt i thought.
I had to take mine in and get new clips installed on my 95.
The plastic line tools are junk.
They dont minipulate the lock very well as the metal ones do.
They used a pick and some pliars to pull out the locks, and then installed new clips inside.
Poor kid who got assigned to it spent 30 mins trying to get it out before he had the fuel tech come over and fix it in like 5 mins. haha
Old Oct 9, 2006 | 11:59 AM
Andyman8282's Avatar
Andyman8282
I spent a good 20 min under my truck trying to get that filter off for the first time. I finally broke down and bought some metal tools at a local auto-parts store, they did the trick in 2 min. after I figured out how to use them.
raytasch
Feb 5, 2011 10:57 PM
Chevy 6.2D
Jun 24, 2008 10:26 AM
fordtruck88
Jul 4, 2007 10:24 PM
Lukes66
Feb 4, 2003 09:20 PM
BruceN
Oct 13, 2001 08:45 PM
