failed #2 & #8 cylinders
Old Oct 7, 2006 | 01:36 PM
hotbikes's Avatar
hotbikes
Question failed #2 & #8 cylinders
help-- my son has a 05' f350 6.0 and has been denied warranty because of aftermarket acceccories (chip) Manufacturer said no way there product could have been the cause of just those 2 cylinders to fail. all other cylinders look find. is there a known problem on the drivers side of this motor??? please help
Old Oct 7, 2006 | 02:13 PM
wlihntr's Avatar
wlihntr
this would be better posted in the 6.0 forum, maybe one of the mods can move it. what to you mean cylinders failed? did they fail a contribution test are they damaged are the pistons burnt or damaged? i hate to say it but a tuner and a heavy foot can cause all kinds of problems.
Old Oct 7, 2006 | 02:21 PM
Hootbro's Avatar
Hootbro
That is why you mod outside of warranty. Either side will blame the other to avoid warranty costs. Expensive lesson but you are hosed IMHO.
Hootbro
Old Oct 7, 2006 | 02:43 PM
tvsjr's Avatar
tvsjr
I'm afraid hootbro is probably right. Ford knows about the chip, the warranty is gone, and you can forget about the chip manufacturer doing jack for you.
Unfortunately, it's going to be a long and expensive repair.
Old Oct 7, 2006 | 02:57 PM
hotbikes's Avatar
hotbikes
thanks to all for replies, but why would just 2 cylinders show burn paterns and not the other 6. why did the valve hit the #8 piston. and yes the heavy foot did not help!!!!!!!
Old Oct 7, 2006 | 03:03 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Hint for "next time". Remove all traces of the aftermarket equipment prior to taking it to dealer! Maybe you would try doing just that at a different dealership...maybe first one didn't send the info in on an Oasis report. If you get a "Sorry Charlie", nothing lost, right?
Old Oct 7, 2006 | 03:13 PM
hotbikes's Avatar
hotbikes
forgot to mention that they were assumming a chip was on this vehicle. the chip was removed long before the problem occurred.
Old Oct 7, 2006 | 03:39 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Moved to 6.0 forum
If there's contact between the piston and a valve, it almost sounds like it was over-revved and the valve floated.
But since it's no longer "chipped", shouldn't it be impossible ?
These days "chipped" could mean a programmer was plugged in, the computer program changed, and the programmer removed. You could still have an updated program in the computer, which Ford noticed. If that's the case, the warranty is gone.
However, what I'd do is tell them to provide (in writing) proof that it's been chipped.
And get a Ford service rep to check it ...
Old Oct 7, 2006 | 05:00 PM
Maxium4x4's Avatar
Maxium4x4
Welcome to FTE hotbikes
Read First: https://www.ford-trucks.com/guidelines.html
I play but I do my own work on the truck. A technician can see a star pattern on the piston. A valve hitting the piston could be from a lifter, that needs to be addressed and looked at.
Private message me your VIN and I'll see what the OASIS has going.
Old Oct 7, 2006 | 05:27 PM
krewat's Avatar
krewat
Maxium4x4 to the rescue!!!
ekm71f100
15
Jan 23, 2012 01:38 PM
F350-6
106
Apr 17, 2009 10:30 PM
PowerstrokeJunkie
28
Sep 1, 2008 02:09 PM
gov2mod
Nov 8, 2004 03:26 PM
wickware
Sep 8, 2004 05:49 PM
