i have a 2000 ED with a 5.4 it has 93K on it.. what is the best way to gain the most amount of fuel milage.. the most i have seen my truck get it 11MPG?? should i start with plugs and wires? which are the best? i have only had my truck for a few months so any experianced people in here with some good tips for me please help thanks..
It's the simple things. Air filter, tire pressure and press lightly on the little pedal on the right. At 93k I'd look at the plugs and see. Maybe the previous owner had them changed. Make sure all fluids are in good condition and topped off
I noticed a big change when I put a new fuel filter on. Also, check and make sure that your thermostat is functioning normally. If it's stuck wide open, the engine will run cooler then designed and your mileage will suffer.
Here are a few things that I have found to be great for fuel economy. This goes for any late model car.
o2 sensors is a biggy "Have made HUGE gains just by this alone" Cataletic Converters If EGR is in place it needs to be operational ALL Filters applicable Clean MAF wires/probe Plugs & wires of course Fuel system clean "injectors" A good dyno tune will improve milage as well as power.
Like the other fella said....Keep your foot out of the go-pedal when you can. This is really key.
You can easily piggy-back your ECM with a chip that has several modifications to your stock tune. It can really clean up your A/F values as well as several other aspects like the speed of your cooling fans, trans-shifts, etc. You can use a flip-chip with three custom tunes to your liking and needs; economy, towing, Max Power.
Dyno-meter...Do a simple google search and see what ya come up with.
Good Luck,
Brad
From my own experiences, I'll second everything listed above--in particular, a functional thermostat, tire pressures (I'm running 40 psi) and especially keeping a light foot on the throttle, and no flooring it at stoplights.
We just got back from Outer Banks, NC this weekend in my '01 5.4 4x4 and with a full load of luggage and 4 adults, we were getting between 17.3-18.2 MPG. Yes, this is on a vehicle with 91k miles on it.
i just changed spark plugs, air filter and fuel filter and i t made a big difference, i have a 99 expy 2wd with 185k and just got back from a 2k miles round trip getting around 19mpg avg. tire pressure makes the biggest difference if not set right, i run 35 around town and bump them to 40 for hwy, hopes this help
Bumping your tire pressure can help with MPG, but be careful when you do it. If you overinflate the tire for the load you are carrying you end up riding on the center of the tire and will wear that out quicker. You also shrink your contact patch and that can be a very bad thing if you come on adverse road conditions. I make sure to keep my tires inflated properly for the load I am carrying and leave it at that. Tire pressure doesn't make a huge difference in mpg assuming that you are not 15psi low to begin with.
