89 with rough idle
Old Oct 6, 2006 | 07:28 PM
Tradesman E's Avatar
Tradesman E
89 with rough idle
I’ve got a low mileage 1989 E-350 with a 351 engine. I could use some help trouble shooting a rough idle problem. Acceleration and overall driving is good. <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Thanks, Tradesman E<o></o>
Old Oct 6, 2006 | 07:56 PM
Davetopay's Avatar
Davetopay
What kind of care has it had? Are all the vacuum hoses good? How about a general tune up? Plugs, cap, rotor, wires, pcv, egr cleaning, MAF cleaning(if it has one). If it has been sitting for a long time, I woud suggest running a few cans of BG44K fuel system cleaner through it.
Old Oct 8, 2006 | 11:32 PM
Dannym's Avatar
Dannym
upper-to-lower (plenum) intake manifold gasket- likely
vac leak. Check the vac lines where they pass over the passenger side exhaust manifold. Check the steel "coffee can" vac reservoir behind the starting battery for rust (very likely!)
slack in timing chain (you say low mileage so I would find it unlikely)
Old Oct 9, 2006 | 10:19 AM
misteramx's Avatar
misteramx
tradesman -
Having struggled with my '89 E250 and fuel injected 460, I can tell you a few things. First off, you don't have MAF, you have speed density. So, don't try to clean the MAF...you don't have one.
On my van, I found that one of the plug wires was actually sparking through the boot and arcing to the exhaust manifold. Easy enough to see it, put the van in the shop where there is little light and start it with the dog house removed...you'll see arcing if the wires are bad. My wires were the factory originals and although they looked to be in very good shape, they weren't. A complete tune up is in order 1) because it can resolve the problem and 2) if it doesn't fix the problem, then you have a correct baseline from which to start looking at other problems.
I too had a rough idle, loss of power at full throttle, and a check engine light. I replaced the fuel filter, air filter, plugs, wires, cap, rotor, and PCV valve. The van runs vastly better now. Also, the EGR can be the problem as well.
Start with the tune up and see where that gets you. I think I spent a total of $100 including having someone else do the fuel filter and the rest myself.
Keep us posted...
Old Oct 10, 2006 | 06:37 PM
Tradesman E
Good info Guy’s
I’ll start with the basic stuff you pointed out, since I don’t drive her much, she doesn’t get any attention most days. Thanks Tradesman…
Old Oct 10, 2006 | 07:58 PM
Davetopay's Avatar
Davetopay
Good call on the vac canister. My 78 is leaky there and idles like crap until it is warmed up.
KRH1326
1983 - 2012 Ranger & B-Series
Mar 3, 2011 03:55 PM
losealot
Jun 19, 2008 01:12 PM
michaelgr
Bronco II
Jan 10, 2008 02:53 PM
cj_poole
Nov 16, 2006 12:07 PM
