Transmission Problems 2002 SportTrac
Old Nov 15, 2006 | 01:45 PM
cj_poole's Avatar
cj_poole
Our 2002 Explorer Sport Trac is having Transmission issues. <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
It was shifting rough, delaying between 2nd and 3rd gears.<o></o>
I had the Transmission serviced as per the maintenance schedule.<o></o>
The problem continues and now the O/D light is flashing on and off when I drive it.<o></o>
<o></o>
Any ideas?
Old Nov 15, 2006 | 04:08 PM
Virginia Donkey's Avatar
Virginia Donkey
There is no maintenance interval on the 5 spd auto in the owners manual. you should get the codes pulled, but it sounds like a big $$ contribution to your favorite trans specialist is in you immediate future.
Old Nov 16, 2006 | 12:07 PM
aquanaut20's Avatar
aquanaut20
The flashing O/D light indicates the tranny is in limp mode, check the connection block on driver side of tranny, pull codes, clear codes, see if they come back, then post here...
was the correct fluid used at the service, check!
BluGator2000
Jun 12, 2020 06:56 PM
plum bob
18
May 31, 2018 12:06 PM
Eagle Spirit
Engine Swaps
May 20, 2014 01:04 PM
