Sponsored by: Real Truck
If I had a jack.....
Old Oct 6, 2006 | 06:52 PM
Zip's Avatar
Zip
where might I find it? I have a 99 F250 SD S/C 4x4. I can not find it or even a spot where it may have been.
Old Oct 6, 2006 | 07:02 PM
Pocket's Avatar
Pocket
On my crew cab it's behind the rear bench seat on the passenger's side. I'm not sure if that's the same spot as the supercab. Might be worth a look.
Old Oct 6, 2006 | 07:17 PM
tigerman's Avatar
tigerman
It's under the back bench seat (passenger side) on my extended cab '99. Maybe yours is the same. Just for the heck of it, I've used it in my garage on both the front and rear. It worked pretty good. But I still carry an extra screw jack (a big heavy one that you can't buy anymore) and a bottle jack just in case.
Old Oct 6, 2006 | 07:31 PM
George Frasier's Avatar
George Frasier
Not familiar w/ the year, BUT, if it has steel bumpers - why not get a Hi-Lift jack ? THAT will lift a semi AND can be used to pull yourself out of trouble when stuck.
Old Oct 6, 2006 | 08:11 PM
Pocket's Avatar
Pocket
No way I'd lift my truck with the bumpers. I've looked at how they are mounted. Plus my truck tops the scales at 7900 lbs.
Old Oct 6, 2006 | 08:17 PM
blakerj10's Avatar
blakerj10
mine is behind the seat of my 05 regular cab
Old Oct 7, 2006 | 09:27 AM
DetailerDave's Avatar
DetailerDave
Mine is under rear bench seat, pass. side. Lug wrench is under the hood, over the radiator.
Old Oct 7, 2006 | 12:19 PM
sifon187's Avatar
sifon187
Mine should be behind the bench seat, but I failed to check for it when I bought it. I hope I dont get a flat any time soon
Old Oct 7, 2006 | 03:03 PM
350z's Avatar
350z
Mine is underneath the pass rear seat, Craig.
