E4OD, E350 94, transmission problem code 653 853 663 211
Old Jun 21, 2018 | 09:16 AM
rvE350_1994's Avatar
rvE350_1994
Hi guys ! Need help please, sorry my english .. my truck is an rv E350 1994 E4OD transmission and on the highway, the cruise control get off and the motor revolution get up of 400rpm, and when I slowdown the truck seems to be in Limb mode, high rev shift.. the codes I get are; 653 853 663 211. Any ideas ?
Old Jun 21, 2018 | 09:30 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The most important one is the code 211. That's an engine ignition fault. Here are some ideas of what could cause that:
Profile ignition pickup (PIP) -circuit malfunction - Wiring, poor connection, arcing secondary ignition component coil/cap/rotor/HT leads/ plugs, electrical interference, ECM
All of the other codes could be caused by this problem. Get this fixed, clear the codes, and see if it's fixed.
Old Jun 21, 2018 | 10:18 AM
rvE350_1994
Thx for the reply, about the code 211, the first time of the season I have started the truck It did not start, I turned the key but nothing except dash lights, after few try the truck started. I was thinking this is why I got the 211 code.. what do you think ? I can clear the memory and scan it again after the transmission goes back in Limp mode ?
Old Jun 21, 2018 | 02:12 PM
Mark Kovalsky
Yes, try that.
Old Jun 22, 2018 | 07:40 AM
rvE350_1994
This morning I run the self test key ON but engine not running, I got code 452 (vss signal too low) Im thinking to change the vss sensor cause its easy and low cost. Clear memory and take a ride.. Im also cleaning the connectors on the transmission, the One on passenger side was full of oil O_o
gnuiver
1978 - 1996 Big Bronco
May 24, 2021 07:13 PM
rvE350_1994
Jun 25, 2018 08:54 AM
jmuenchow
Sep 11, 2015 02:59 PM
92will
Jul 28, 2011 08:28 PM
kiohio1985
Aug 30, 2006 08:20 AM
