tires
Old Nov 5, 2006 | 12:27 AM
  #31
jhooch's Avatar
jhooch
Definitely the Toyo MT. You will not found a stronger casing. 7-ply tread and 3-ply sidewall. Load Range E. Ran 285/75-16's on my '04 F350 6.0 Crew 4X4, now have 33X12.50r-18's on my '05 6.0 Limited X. There isn't a better tire out there.
Jhooch
Old Nov 11, 2006 | 10:09 PM
  #32
nnygaard's Avatar
nnygaard
01 X v10 LPG converted: I'm planning on a mod that includes custom shocks, rear swaybar and slight lift ~2 inch f/r, amo. 295/75-16's are part of the qualified recipy - So far the only brand I have found for this dim. are the BFG's - until I stumbled over General Grabber AT2 the other day.
They should even be great for winter conditions -which is quite important here in Norway.
Anyone of you guys in the US have experience with the Grabbers?
Old Nov 15, 2006 | 04:05 PM
  #33
jhooch's Avatar
jhooch
We also stock the Toyo Open Country A/T in that size.
Jhooch
Old Dec 1, 2006 | 09:20 AM
  #34
Jughead's Avatar
Jughead
I'm looking into tires right now.....Goodyear Wrangler Silent Armor E rated. supposed to be good in the snow.
Old Dec 1, 2006 | 09:54 PM
  #35
Fifty4F100's Avatar
Fifty4F100
I was told when I bought my BFGs that Goodyears of this size are hard to balance. One guy was making Sam's good on there money back guarentee and trading the Goodyears for the BFG Long Trails that I bought. He only had a 1/2 ton truck.
Old Dec 4, 2006 | 06:02 PM
  #36
Hoser333's Avatar
Hoser333
If they have a Discount Tire Store in your area, check with them.
I've found that BFG's are too soft and wear quickly
Old Dec 11, 2006 | 05:49 PM
  #37
nnygaard's Avatar
nnygaard
So, nobody with any experience about the General Grabber AT2s? Somebody of you across the pond must know them??
Just ordered a set in 295/75-16 - hard to find a dealer here in Norway - but finally. Will have them some time end of this week. We'll see...
01 Ltd 4x4 V10, LPG converted, no the mod is done: 1.5" lift, +4 degree caster, swaybar and custom tuned Koni HD shocks. New Rig, say no more. 295 will top it off.
I'll let you know.
Old Dec 13, 2006 | 08:23 PM
  #38
9wire's Avatar
9wire
Just mounted 315/75's on stock wheels on my 2000 limited.Only had to pull back the plastic inner fender a bit with some wire ties,but have a little rub on the leaf spring at full lock.BFG a/t KO's.Can I adjust the steering stops?It really is at the stop and does not rub very much,not at all during regular driving.
Old Dec 13, 2006 | 11:10 PM
  #39
jhooch's Avatar
jhooch
9wire, just wondering why you would want to run a tire spec'd for an 8.5 inch wheel on a 7 inch wide wheel. You'll never get a flat footprint since the tread contact patch will only be as wide as the wheel. That means you are wasting the outer edges of the tire. The edges will cup as a result since they do not make good contact with the road surface. Do yourself and your new tires a favor and put them on at least an 8 inch wide wheel. I don't understand why so many tire dealers don't disclose this to their customers when selling tires. Probably because the salesman was either uneducated or only cared about "getting the sale". Putting your bottom line before your customers best interests is always a recipe for failure in any business. Just my .02 worth.
Old Dec 14, 2006 | 06:58 AM
  #40
9wire's Avatar
9wire
I'll look at it a little closer,they look ok,but you might be right.
Old Dec 16, 2006 | 09:14 PM
  #41
William Gardner's Avatar
William Gardner
I put 285/75 R 16s on my 2001 F150 4x4. They are made by Cooper and sold at Pep Boys under Futura brand. They make HT and AT. I went with the more agressive AT.
They are awesome so far and about 33 in. tall. The stock 8 in. mags took them with no problem and I got out of there for $544 including everything.
Old Dec 16, 2006 | 11:51 PM
  #42
jhooch's Avatar
jhooch
285's are actually 32.5" tall, you can round to 33" if you want. I would double check that stock wheel width, all OE Ford wheels were 7" wide as far as I know. Came standard with either 235 or 255/70R-16's. The other option was a 265/70R-17 and those wheels were also 7" wide.
Old Dec 19, 2006 | 07:35 PM
  #43
nnygaard's Avatar
nnygaard
Smile Grabbers fitted
Got hold of a set of 295/75R16 General Grabber AT2s yesterday. Fitted today, turned out easy to balance. Almost noiseless on road, despite aggressive thread. Tests passed very well on wet tarmac and slushy snow. Offroading and icy conditions yet to be tested. I'll get the chance in short time. The modification scheme is now completed with the right size rubber, boy what a difference from stock! Can't figure out why Ford didn't build em like this in the first place.
Happy 'new'-X rider .
-2001 X,V10 4x4 Ltd, mods: LPG conv, 4cm lift, rear swaybar, 4degr increased caster, softer front susp. comp. pads, KONI 4x4 Heavy Track-based custom shocks, 295/75R16 on stock wheels.
Old Dec 19, 2006 | 10:34 PM
  #44
quietman's Avatar
quietman
<IMG SRC="http://www.martialartsacademy.org/levi%20picture.jpg">
The local Allen tire near me will not put tires on that do not meet the manufacturers requirement for width etc.
HOWEVER
Every other tire store and the LOCAL FORD DEALER puts 315/75/16's on thousands and thousands of superduty Fords with stock rims...as has been and is being done Nation-wide for years.
seems to work.
I know I am in love with mine after going from 265's to 295's and finally getting the "real deal" tires after two years and 40K miles.
If you just hamster-pound the pavement or drive the kids to soccer games then you don't need bigger tires.
If you tow gigantic things you probably don't want bigger tires.
If you don't have a diesel...well,....sorry.
_____________________
Quietman
www.roenation.com
2005 EXCURSION LIMITED-options (everything) equipped Eddie Bauer edition 4X4 PSD
4" FabTech lift/level, Bilstein $$ mono-gas shocks, Rancho Steering Stabilizer
Silverstar 9005 fog and H13ST headlights + wiring mod to run high beam and fogs together,
BFG 315/75/16 AT KO's on Factory Mags, 22" front and 18" rear rain-x wipers,
LANDYOT Generation II Radius Rods, Ford factory hood insulator
Old Dec 19, 2006 | 11:43 PM
  #45
jhooch's Avatar
jhooch
Just because most tire dealers will do it as well as the Ford dealer doesn't necessarily make it right. Ford engineers would never spec a tire that wide on a 7-inch wheel nor would the tire manufacturer recommend it. I've been in the tire business for over 15 years and have seen a lot of people throw shocks, front end parts, alignments, and a lot of cash at their trucks to stop irregular wear when in many cases it was just too wide a tire for the wheel. When finally explained the root of the problem many wonder why they weren't told in the first place. I'm not here to reprimand anyone, just here to educate. If a customer absolutely want 315's on a stock width wheel we will give them what they want, but after they have been educated on rim width matching and footprint. A lot of people are under the impression that if the size ends in 16, the tire will go on any 16" wheel and that's just not necessarily true. I'm not saying you CAN'T do it, I'm just saying I don't recommend it. BTW, I run 33X12.50R18 Toyo MT's on 18X9.5 wheels on an '05 6.0 X with nothing more than a front add-a-leaf and air bags in the rear. They do rub the plastic at full lock but I can live with that. Sorry about the length of this post, I'm just very passionate about what I do. Just think about how much "beefier" those tires would look on wider wheels though....
