1978 - 1996 Big Bronco
79 Bronco wont start
Old Oct 9, 2006 | 06:47 PM
THE KING's Avatar
THE KING
Sounds like a Neutral Safty switch. That happened to me, I pulled it in the garage, Restored it, got it close and i tryed to start it and nothing. I replaced the battery and the slenoid and nothing. My dads friend came over and said it could be the safty switch. We bypassed it and started rite up. Not the safest thing to do but it got it out of the garage. Good luck!
Old Oct 10, 2006 | 10:59 PM
robins79 custom's Avatar
robins79 custom
yup it was the alternator regulator no prob's since i changed it
Old Oct 11, 2006 | 10:27 AM
MBBFord's Avatar
MBBFord
Question
Originally Posted by bertha66
Yes, it can be ajusted. You can bypass it by hooking the wires togather to see if this is indeed the problem.
Ok, I've got some questions. What do you need to do to bypass it? Take the wires out and connect them to each other, or is adjusting it the best thing to do?
Old Oct 11, 2006 | 11:43 AM
bronco521's Avatar
bronco521
you can bypass it for testing but it should be hooked up for safety reasons.elongating the holes is if the shifter is in park and it won't start but you wiggle the shifter or hold it up and it starts it needs to be adjusted.
terrylamar
20
Aug 24, 2017 11:18 AM
ben73058
Dec 10, 2016 04:29 PM
pinkyracer
Apr 9, 2015 11:14 AM
dirtybird96
Oct 16, 2010 04:23 PM
Chopper-Boyz
Aug 3, 2003 03:38 PM
