np 435 rebuild gone wrong!!!!
Old Oct 5, 2006 | 12:06 AM
terran05's Avatar
terran05
Unhappy np 435 rebuild gone wrong!!!!
I just put new bearings, syncros and new first and reverse gears in it and A new input shaft, mated the tranny and transfer case together and now first and reverse wont spin. third and fourth are fine but when u go to spin it in reverse or first it really hard to spin if at all. what did I do wrong?? its not in the truck yet but wanted to see it turned. like I said its turns really well in third and fourth second Kinda hangs up too. HELP!!!!!!
Old Oct 5, 2006 | 12:38 AM
Mil1ion's Avatar
Mil1ion
Maybe check in the drivetrain forum or the 4x4 forum ?
Old Oct 5, 2006 | 02:38 AM
FordPickup460's Avatar
FordPickup460
Its possible to get the gears in backwards.
Old Oct 6, 2006 | 03:56 PM
794x4390's Avatar
794x4390
Make sure that you got the shift forks grooves onto the blocking ring correctly or it's possible to get it in two gears at once, which ain't gonna get you anywhere.
Old Oct 7, 2006 | 02:58 AM
"Beemer Nut"'s Avatar
"Beemer Nut"
Sounds like you missed ths fork slot on the gear, reverse seems to be the one that gives the most trouble.
I ran across a good rebuild section last week, PM for information if needed.
.....=o&o>.....
Old Oct 7, 2006 | 05:59 PM
terran05's Avatar
terran05
well thanx guys. The shift tower will have new forks on it and I will make sure that forks got set in there right. thanx
Old Nov 5, 2006 | 06:09 PM
terran05's Avatar
terran05
some good news I got the forks in the slots but reverse and first seem to be turning but very tight. should I take them out and maybe sand each gear till they mesh well or just put it in the truck and take it easy till they break in?
Old Nov 5, 2006 | 07:59 PM
"Beemer Nut"
Somethings not right, you have enough end clearance on the input shaft? You checked the synchro clearances?
I wouldn't run it as it could destroy itself and lock up on the road then what, go thru another box and labor?
oldandretired
Nov 18, 2016 08:37 PM
Mattlewmadeit
Jul 28, 2016 08:42 AM
jdsgtball
Modular V8 (4.6L, 5.4L)
Apr 19, 2015 05:19 PM
cookkd
Aerostar
Mar 17, 2009 02:31 PM
billyb
Mar 30, 2008 07:15 PM
