E350 diagnosis
Old Nov 18, 2016 | 01:59 PM
oldandretired's Avatar
oldandretired
Question E350 diagnosis
I have a 1990 E350 with 7.5 liter engine class C. It is running hot, I reverse flushed the cooling system, replaced thermostat, water pump and fan clutch. Next time out started heating up again then could not accelerate unless feather the throttle until I got to third and fourth gears. Once I got to third and fourth, could accelerate again.
Any ideas?
Old Nov 18, 2016 | 06:18 PM
blageurt's Avatar
blageurt
is it carbeurated.... ie; does it have carb....sorry for the spelling I just blazed......
Old Nov 18, 2016 | 06:37 PM
oldandretired
It is fuel injected and runs good. Once in third gear has good power.
Old Nov 18, 2016 | 08:01 PM
Spaznaut's Avatar
Spaznaut
Correct rotation water pump? What did the fluid look like when you flushed it and how did you flush it? Does it run hot at idle or only when moving? Feeling of your radiator are your fins hot all the way down? (No rows blocked) I had a 460 that I had to drill small holes in the thermostat to get it to burp the air out easily. Are you losing any antifreeze? Can you hear it boiling when you come to a stop? When you hit 3rd and 4th gear is it still overheating or has the temps come down with the increase in speed.
Old Nov 18, 2016 | 08:37 PM
oldandretired
Yes correct direction, the cooling system was clean, hot only moving, no rows blocked, it was burped, not loosing antifreeze now, yes I have heard it boiling, and in 3rd and 4th the temp stays up.
Rachel Nikki Wilson
1997 - 2003 F150
Jun 14, 2014 12:09 PM
dutchlincoln79
16
Jul 11, 2010 10:58 PM
tatesomero
1983 - 2012 Ranger & B-Series
Jul 10, 2004 11:05 AM
hoser4
Aug 3, 2003 10:41 AM
markcrane
22
Jul 29, 2003 09:49 AM
