Jiffy Lube. Take in a coupon, read the paper, no chasing around buring time & gas dumping the old oil off, all other fluids are topped off, cab vacumed, drive away in 20 minutes for $25-30 depenig on coupon. These things are so infrequent it's not worth the hassle anymore to do it in the driveway. Just my $0.02 worth.
I have to take my company car to Jiffy Lube, so far they have left the air filter loose, put in to much oil, drain plug stripped, plus I caught them calling our maintance group trying to replace good items.
Yeah, not to mention crossthreading the drain plug. Mystery oil going in, wrong level, not letting it fully drain etc etc. Seen folks dump their whole pan on the parking lot of a shopping center shortly after an oil change. Not gonna happen to me. It is a labor of love if you will.
JiffyLube willl change the oil on my desiel for $30? Wow, guess I will keep an eye out for that coupon. Normally there is a disclaimer at the bottom of the page that says something like full size trucks extra.
Steve
Jiffy Loose! On Vacation driving from Rochester, NY to BH, Maine.
First thing I did was stop in Roc at JL for fresh oil.
35 miles down the road oil light comes on. Checked oil level, no reading on the stick. Checked under car and there is my oil.
In the middle of nowhere I had to redo my oil change and filter on the side of the road because the filter had no rubber gasket.
JLs reply to my complaint was "If you returned to us we would have fixed the problem".
I have not returned and never will.
Best of luck to those of you who trust your vehicle to others. A friend had his wiper fluid topped off with antifreeze!
I would never let a $5/hr Jiffy Lube or Wal-Mart guy touch my truck, ever. They're not even allowed to look in the window let alone do some work to it.
