EFI to CARB
Old Oct 3, 2006 | 04:43 PM
1990 f-150's Avatar
1990 f-150
EFI to CARB
I have a 1990 f-150, and i was going to swap out the 5.0 with another 5.0, but the other one has a carb, what would I have to do to change to a carb motor instead of the original efi.
Old Oct 4, 2006 | 11:13 AM
loudfords's Avatar
loudfords
Just put the EFI stuff on the new engine, much simpler and cheaper than converting the truck.
Old Oct 4, 2006 | 04:18 PM
ABA's Avatar
ABA
All you got to do is run a electric fuel pump for a carb. EFI pumps run at a higher pressure. Carb only needs about 5 to 7lbs.
Then you can trash all the computerized garbage.
I swapped out a 3.8 for an old school 302 in my '93 T-Bird but I had to cut a hole in the hood so that carb could get some fresh air. LoL
Old Oct 4, 2006 | 05:25 PM
ABA's Avatar
ABA
Your going to need a shorter throttle and kick down cable and you may have to run a toggle switch for your coil.
I tried powering coil off some stock wiring and relay would trip out. Toggle solved that issue.
Old Oct 5, 2006 | 07:17 PM
1990 f-150's Avatar
1990 f-150
could i just cut my throttle cable, and what is a kick down cable, could i just get a new distributer thx
Old Oct 5, 2006 | 08:05 PM
ABA's Avatar
ABA
Kick down cable on older vehicles is what make transmission go into passing gear.
On newer vehicles with AOD trans it controls the transmission's pump pressure so that it shifts right.
Do you have and AOD trans?
You may or may not get by cutting the throttle cable, depends on the linkage. I'm not familar with your trucks settup. I'm just going by what I had to do to my T-Bird.
Old Oct 6, 2006 | 05:54 PM
baddad457's Avatar
baddad457
You did something wrong there. I've had the coil on my 89 Ranger running off the factory coil hot wire now for 5 years. Distributor is a rebuilt points type fitted with a Pertronix II and fed by a Mallory Promaster points type coil.
Old Dec 10, 2006 | 05:08 PM
inlineguy's Avatar
inlineguy
im in teh process of swaping a efi staight six for a carbed 302 i think i am just going to paower the coil form teh starter solinoid and run a inline fuse. i dont know if i iwll drop teh tanks and remove the intake pumps or what yet anyone have any suggestions.
williameub
Sep 14, 2013 05:05 PM
austinlittle34
Engine Swaps
Jun 14, 2013 10:44 PM
bigtoyboy
Engine Swaps
Jun 13, 2011 10:46 AM
onan302
May 15, 2011 08:05 AM
bearster18
Oct 7, 2007 12:11 PM
