Sponsored by: Real Truck
Clunking Rear end
Old Feb 10, 2011 | 05:51 PM
drewskeez's Avatar
drewskeez
Clunking Rear end
Alright, I haven't posted in a while...my truck has been behaving nicely.
But...
On cold mornings/days I get a series of clunks from the rear end area. It only happens on the first movment and when it is cold. Reverse or forward. It's not a frozen to the ground type problem.
Any ideas?
2003 f250SC 5.4l
Thank you,
Drew
Old Feb 10, 2011 | 06:18 PM
Bobcat7's Avatar
Bobcat7
The ol' ladys exploder used to clunk a bit w the limited slip. The clutches must've been stuck to each other and needed to go 'round the first few corners first.
Unless the pins the calipers slide on are severely worn and the calipers are slopping around. I did brakes last fall and mine had rust inside of the little rubber boot and the pin didn't move very well. Wear one pad out quick.
Old Feb 10, 2011 | 07:21 PM
redford's Avatar
redford
FTE Leadership Emeritus
(Something you never thought you would tell another guy)
Maybe you need a little more grease in your slip joint.
Old Feb 10, 2011 | 11:22 PM
bunklash's Avatar
bunklash
redford said, "Maybe you need a little more grease in your slip joint".
Fixed my clunk! (in my truck)!
Old Mar 24, 2011 | 07:16 AM
Tmill's Avatar
Tmill
That just happened to me the last 2 mornings. This is killing me. Over the last week I've been gathering info on a possible broken exhaust manifold stud plus some other small gremlins ?!@#$. Now this is happening and I just want to slam the door on my head a few times.
Old Mar 24, 2011 | 08:39 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
If it is your slip joint that is the problem, here is how to fix it. LINK
Old Mar 24, 2011 | 08:54 AM
BassFantasizer's Avatar
BassFantasizer
I've had the same problem with my '97 F-150 since the day that I bought it. Ford swore to me repeatedly that "it's the nature of the beast". Despite FIVE rear-end replacements (gears/internals) from 30,000 to 65,000 miles it continues to this day.
The rear end is still junk (at 187,000) and the clunking has just become a way of life.
Old Mar 24, 2011 | 12:27 PM
Tmill's Avatar
Tmill
Millner_Feed. Awesome link!! Everyone has been saying that it was an easy fix. I guess I was sorta hoping to just grab my grease gun, crawl under and grease it. That's not going to happen thanks to Ford. I should be able to take this on. Thanks for your help.
Travis
Forgot to ask. I have some all-purpose grease and some marine grease, will they work? Or do I need some other stuff?
Old Mar 24, 2011 | 06:56 PM
ddesens's Avatar
ddesens
Use the marine grease its better for water exposure.
Old Mar 24, 2011 | 08:35 PM
Benchwrench's Avatar
Benchwrench
I think the best thing to do is tap a zert while it's apart.
1Reddog
2004 - 2008 F150
Mar 31, 2014 06:48 PM
FarmingFord
Dec 10, 2009 08:24 AM
drewk86
2004 - 2008 F150
Aug 13, 2007 06:09 AM
sport_trac_drew
Nov 21, 2006 12:36 PM
DeepRoots
Sep 1, 2005 07:30 AM
