I have been experiencing some squeaking/squealing when I start up my truck, very loud. It squeaks only when idling, the squeak goes away when I give it a little gas. The sound is reminiscent of a belt/pulley problem but it is intermittent, doesn't always do it. The belt is in great shape, pulleys are all tight and bearings and good.
I'm not sure if it was a coincidence but it also seems like the times that it HAS squeaked I had started the truck from being cold (hadn't run for a few hours) IN COMBINATION with having the vent on in the cab. Other cold starts without any vent running I didn't get the squeak. If I run the truck for a bit and THEN turn the vent on, no squeak. Anybody have any suggestions?
Moisture can get on the belt and cause it to squeak. Even if the belt looks in good shape it could still be stretched. Try getting a new belt and see if that fixes it.
I did notice that the tensioner was very easy to move when I removed the belt and also that it was bouncing around quite a bit when the engine was idling. The only thing that made me think it couldn't be the tensioner is that the truck never makes the noise if the engine has been running for a bit, even if the tensioner is still bouncing around. What do you think?
When you start from cold the starter draws a hefty current from the battery. As soon as the engine fires the alternator loads up to replace the charge in the battery and so puts extra load on the drive belt causing it to slip. Replace the belt and tensioner as already suggested.
One other thing that I should mention. On the same day that I first heard this noise I also got a check engine light about a mile down the road. I later found out that the codes for that light were:
332 (Continuous memory code) - Insufficient EGR flow detected
335 (Key off engine off code) - EGR Sensor Circuit Voltage Higher or Lower Than Expected During Self Test
Both EGR related. I posted another thread about remedying my EGR situation but could the squeal be related to a bad EGR component (sensor, valve, etc.)? Or was this just a coincidence.
Just an idea. I had a Ford vehicle recently that would have a high pitch tone only in idle. It wouldnt happen all the time and could be light or very loud at any given time. I give it a little gas and it went away, but would come back when the truck idled down again. I took a screw driver handle and I started tapping around a little under the hood while it was making this sound and found that if I tapped the IAC valve on the side of the intake plenum, I could make the noise disappear, re-appear and change tone. I replaced the IAC valve and the problem went away. Maybe you could try tapping the IAC valve while its making its noise and see if it changes.
I would suspect that the spring in the belt tensioner is getting weak or the belt is worn and elongated.
When I changed my tensioner and belt--the truck got real quiet and new sounding again.
Familier sound. I was driving home this afternoon and listening to my truck do the exact thing. Just a slight singing of a belt when the engine was idling. Any touch of the throttle and it cleared right up. Belt is fairly new (Dad replaced it when he replaced the altenator last season) so the tensioner sounds like a good place to start. She's only got 266k miles on her now so it might just be getting a little tired. (Dad just retired from farming last month and let me take the big old girl home. Took 4 new tires and a radiator this weekend to get her home.) Got a few things that will need some attention this weekend (like fixing the power windows and looking at the AC), might as well add this to the list.
