Gcvwr
Old Sep 30, 2006 | 06:30 AM
burnmark's Avatar
burnmark
Gcvwr
I saw here somewhere that an 80's or early 90's 7.3 only had a 13000 GCVWR? Was that an error?
What would a 95-97 be able to pull? And/or what would be the GCVWR?
m
Old Sep 30, 2006 | 07:18 AM
Cuda_jim's Avatar
Cuda_jim
Ford calls this GVWR, should be the same thing? It's actually the brake type rating for complete vehicles, not for buses & motor home chassis.
It's the 4th letter in the VIN for 96-99:
M=19500
L=16000
K=14000
J=10000
H= 9000
Old Sep 30, 2006 | 07:31 AM
burnmark's Avatar
burnmark
Actually, I'm referring to the combined weight rating, ie- truck + trailer. The truck's GVWR tends to refer to just the truck itself, so about 8800 lb for a 3/4 ton, and I think most of the 1 ton's go about 9900 up.
m
Old Oct 1, 2006 | 01:27 AM
believer45's Avatar
believer45
Mine has a 5 speed and 3:55 gears and I believe the GCWR is either 15,500 or 16,500. With the auto and 4.10 gears the GCWR is 20,000 lbs.
Dave / Believer45
Old Oct 1, 2006 | 01:45 AM
andywe's Avatar
andywe
Re: Gcvw
Believer is correct. My 94.5 5 apeeg manual has a 4:10 axle and is good for 20,000 combined. Brakes are ABS as well.
Keep in mind when towing, that no matter what it is rated, you are always better off giving yourself a buffer zone.
Thenewboss
All Things Towing
Dec 1, 2013 09:57 PM
mabc926
21
Apr 1, 2011 11:08 PM
racinghoss
Jun 17, 2009 09:43 AM
banditsdaddy
Sep 24, 2007 08:43 AM
Turbys_03_Stroke
Jun 19, 2007 07:35 PM
