Overdrive for 65 three speed
Old Oct 1, 2000 | 11:48 AM
walter's Avatar
walter
I have a 65 f100 three speed. I have the problem of high rpms at 70 mph Ive replaced the gears in the rearend with the tallest gears available (don't remember the ratio off the top of my head). My dad had a 62 with an overdrive unit. Does any one know where i might find one and how much it might possibly cost. I just recently put a new 352 in it. Any help would be greatly appreciated thanks.
I'd rather push a FORD than drive a chevy.
Old Oct 1, 2000 | 02:58 PM
jowilker's Avatar
jowilker
Walter this is an observation that I made. If your truck came with an I6, it probably came with 3.75 gears, a 352 3.25, A 352 can pull a 3.00 easily or a 2.75 if you are looking for slower rpms and more economy. Your truck could have been specked differently.
You can do the rotation test to get an idea of your ratio.
John
jowilker@nc.freei.net
66 F100s
In the still cool hours of the night, you can hear chevys rusting away.
Old Oct 1, 2000 | 06:58 PM
dinosaurfan's Avatar
dinosaurfan
The best in overdrives is the gear vendors unit. they have their own web page, search under GearVendors Under/overdrive. their unit consists of three pieces, an input housing, the overdrive, and the tail housing. The overdrives are all the same, .78 to 1, and they can be run behind different transmissions or T-cases by changing the input housing. The units work in any gear, allowing you to 'split' gears, a 3 speed can be a 6 speed. The only reson I don't have one yet is the 2.2K to 2.6K price tag, depending on the input housing you need, they are available for almost anything. DF
Old Oct 1, 2000 | 10:28 PM
jowilker's Avatar
jowilker
Them big price tags can stop you right in your tracks, huh??;-)
You can buy a whale of a lot of gas for that much money. :-)
John
66 F100s
Old Oct 2, 2000 | 07:58 PM
dinosaurfan
John, you are right, 2,200 $$ will still buy alot of gasoline. Especially when I have 2.75's and tall tires just sitting around, waiting for something to do. Cal
Old Oct 2, 2000 | 09:53 PM
TomC's Avatar
TomC
I have 3 Borg-Warner 3 speed w/overdrive units for sale. One light duty and 2 heavy duty. They are passenger car units (slip yoke instead of bolted). They are $100 each or 3 for $200. If one of these will help, Email me for details.
Tom C.
Old Oct 23, 2000 | 10:39 AM
BarryRenfro's Avatar
BarryRenfro
whereare you located?? definitly interested.
Old Oct 23, 2000 | 10:15 PM
Like M. Fords's Avatar
Like M. Fords
