1966 Headlight short
Old Dec 10, 2000 | 02:28 PM
mikes66's Avatar
mikes66
I purchased a 1966 Ford F-100 this weekend and my first project was to figure out what was causing the headlights not to work. All parking lights work put when i pull the switch all the way out for the headlights to come on, the front parking lights go out and the headlights don't come on. Anyone have idea's on where to check for a short? Thanks.
Old Dec 10, 2000 | 03:21 PM
jowilker's Avatar
jowilker
[font size="1" color="#FF0000"]LAST EDITED ON 10-Dec-00 AT 04:22 PM (EST)[/font][p]Mike did you check the bulbs? Have you used a test light to see if there is power to the bulb? Have you checked the fuse?
When you get it fixed post a closing here on this thread.
John
jowilker
66 F100s
In the still cool hours of the night, you can hear chevys rusting away.
Old Dec 10, 2000 | 04:15 PM
driven66's Avatar
driven66
Mike;
On my '66 I had a similar problem. After many hair pulling hours I found out it was a bad dimmer switch. I think that had something to do with the salt and sand they use here in Minn. in the winter.
Old Dec 10, 2000 | 05:15 PM
Nathan's Avatar
Nathan
Just an addition, both my 62 and 64, when the headlights are on, the parking lights go out. Apparently this is by design. Does anyone know why?
Nathan
Old Dec 10, 2000 | 08:20 PM
66worktruck's Avatar
66worktruck
My '66 was actin' kinda funny when the cold weather started, so i laid into the switch w/ some contact cleaner and ran it in and out a bunch of times then i followed it up w/ some wd-40.........so far.....so good
Old Dec 11, 2000 | 01:48 PM
mikes66's Avatar
mikes66
Thanks everyone for your responses, i cleaned the switch with contact cleaner and replaced the dimmer switch and the headlights are now working.
Mike
Old Dec 12, 2000 | 03:11 PM
deerelovr's Avatar
deerelovr
yenrod
2004 - 2008 F150
Mar 15, 2014 05:47 PM
F350moneypit
Jan 17, 2013 08:29 AM
Kaizer88
Apr 1, 2012 09:56 PM
ghunt
Electrical Systems/Wiring
Jan 31, 2009 09:54 AM
STiNGeRX
1983 - 2012 Ranger & B-Series
Jun 8, 2001 10:06 PM
