360 Fuel pressure
Old Aug 4, 2004 | 03:21 PM
ScottJM's Avatar
ScottJM
360 Fuel pressure
Just installed a feul pressure gauge between the pump and carb. At idle it jumps between 8 and 9 psi, at about 2000 rpm it jumps between 9 and 14 real fast. this is a stock fuel pump replaced about 8,000 miles ago is the pump bad or is it somethin else? what should pressure be at?
Old Aug 4, 2004 | 04:29 PM
BB's Avatar
BB
Wow! Should be around 6 - 8 psi.
rusty70f100's Avatar
rusty70f100
Typically with a carb you want about 6-8lbs fuel pressure. Too much fuel pressure and it can blow the float needle open making the float level too high and causing it to run rich. You can get a regulator here.
1918ALF
May 8, 2016 01:16 PM
kevin206
Aug 18, 2014 11:05 PM
tgore3
45
Jul 21, 2009 12:02 PM
nova801428
1983 - 2012 Ranger & B-Series
Dec 13, 2006 09:29 AM
acc7484
Electrical Systems/Wiring
Aug 11, 2005 10:22 AM
