High pressure pump bad?
Old Aug 7, 2013 | 01:07 AM
oldford65's Avatar
oldford65
Have a 1987 4.9 auto That wont crank. Fuel pressure when you first turn the key is around 10 to 15. Keep on turning the key to on it slowy builds up pressure each time. Can hear the pump come on each time for a few seconds. My thinking is the first time the pump is activated it should go up to around 40 or so. Am i correct in assuming it needs a new pump? It has a new filter and a new low pressure pump in front tank. Only running from the one tank
Old Aug 7, 2013 | 09:15 AM
hotrod351's Avatar
hotrod351
you got it. should be around 40psi.
Old Aug 7, 2013 | 09:23 AM
Conanski's Avatar
Conanski
The fuel system should build and hold close to 60psi for the 4.9, and the 'pre '90 trucks have a more complicated fuel system with low pressure pumps in the tanks and a high pressure on the frame next to a "switching" valve and filter. So first thing to do is determine if both pumps are working and if so the problem is with the valve or because of a clogged filter.
Old Aug 7, 2013 | 10:19 PM
oldford65's Avatar
oldford65
Thank you for thr replys. The filter is new and the valve I will check. The intank pump is new as well and it does run. I will use a air hose to make sure the valve is unclogged.
dustmote
Nov 19, 2011 03:08 PM
f100beatertruck
Sep 3, 2007 08:25 AM
HENDEL
Jul 17, 2007 06:40 AM
f150plow
15
Dec 6, 2006 09:58 AM
EPNCSU2006
19
Dec 19, 2003 03:57 PM
