Drive Line Wobble!
Old Sep 27, 2006 | 06:34 PM
Lucky Charms's Avatar
Lucky Charms
Smile Drive Line Wobble!
Hey Folks,
I have developed a uncontrollable wobble in my truck. Its an 87 ranger 2.9L with a 5speed trans.The clutch is less then a year old just put in over last winter. I use the truck to haul wood & to plow snow. I know I know its a little truck & not made for all that. But why have a truck if you can use it for working. Anyway you cant even get out of first gear without it wobbling out of control. I know how to put the trans & transfer case in & out of it but I don't know how to test either one for problems. Should I pull them & bring them to a shop to have them checked or have it towed there?? Ouch$$$$
Any help would be great!
Thanx Matt
Old Sep 27, 2006 | 06:53 PM
decee's Avatar
decee
Are you sure it's not u-joints in the drive line?
Old Sep 27, 2006 | 07:03 PM
85e150's Avatar
85e150
Driveline wobble? As in driveshaft whipping around? My '86 had a delicate little flower of a driveshaft, with dainty u-joints that needed watching and replacement twice in 62,000 miles.
But it sounds like you are talking steering wobble. Again, my '86 had the Ford "Better Idea" crapola plastic fantastic bushings in the tie road and all. It wore out and it was like herding goats to steer it.
If you have loose steering parts and a little alignment issue, a speed wobble, even at low speed, will be the order of the day.
So, either way, I'd either be under it with a fine tooth comb, or I'd be at a trusted shop with a credit card and handgun to make sure they did it right and then pay them to fix it.
Old Sep 28, 2006 | 04:45 PM
Lucky Charms
Thank You for the input.I have checked all the u-joints & front end parts. There is nothing wrong all is tight. I have owned the truck for 4 years & have put allot of time & $$$$ into the steering & suspension. I have all new tires & alignment done to the truck. I can't find anything wrong in that area. Since I work the truck so hard I have put 3 new clutches in the truck with in a four year time span.Now I know what your saying (This guy can't work a clutch!). I have been driving standard transmissions for 30 years from cars to the big rigs I know what I'm doing. I think its somthing with the transmission or transfercase. When you drive the truck its like its pulling a 747 with it brakes on & a LOUD screaming noise commin from the trans area. Also the truck shakes like it has 4 flat tires.I know the trucks new clutch took a beating this past plow & fire wood season so thats why I think its in the
formentioned area. Any help would be great.
Matt
Old Sep 29, 2006 | 11:47 PM
85e150's Avatar
85e150
With a problem this severe, a tear down is in order. Pilot busing worn out, input shaft bearings loose, input shaft/clutch disc all crooked under power?
Something drastically wrong in the TC?
Spun bearings or bad bearings in the trans?
With that amount of noise and drag, something is going to give.
It sounds like you may have reached the limit of your abilitiy to diagnose and fix. Time to get the checkbook out and find someone with a good track record to look, listen and figure it out.
As Dirty Harry said, "..a good man knows his limitations..."
Old Sep 30, 2006 | 01:54 AM
frankenbroncoII's Avatar
frankenbroncoII
the fm 145/146 has a history of the input shaft going bad, and wobbling, then breaking (taking the rest of trans with it). i would check the end play of the input shaft
Old Oct 1, 2006 | 05:50 PM
Lucky Charms
Hey guys!
Im glad to hear from both of you guys. I thought I was imaging this wobble Well I went with my gut & started to take it apart .I have the TC out & Trans almost out.Its that darn clip for hydralic line into the slave cylinder holding me up Well I will have it out tomorrow. I will send both out tobe inspected. I will let you guys no the out come.
Thanx Matt
Old Nov 7, 2006 | 07:04 PM
Lucky Charms
Red face
Well I got the trans out. It turned out tobe the input shaft bearing.I had it replaced & reinstalled the trans. With that said I have not yet tested it.Why you say! Look a my thread in the electrical section under Coil up & die! Let me know if you can help with this problem........
Matt
bmathess304wv
Jun 2, 2022 03:27 PM
John with beastly 302
Sep 16, 2010 03:14 PM
gearhead351
Offroad & 4x4
May 29, 2009 12:10 AM
wantobenav
Aug 18, 2006 10:20 AM
tuffguy
Jul 10, 2001 10:59 PM
