Shifter Kits
Old Sep 27, 2006 | 05:37 PM
FE352's Avatar
FE352
Shifter Kits
Hey I have 1992 F150, Inline six, auto tranny E4OD i beleive, 4X4. Now my question would be this. I was wandering about a shifter kit, are they any good? Do they work well? Or should I just get a new converter?
Brandon
Old Sep 27, 2006 | 07:42 PM
Conanski's Avatar
Conanski
Yes they work. They are designed to increase line pressure and as a result make the shifts firmer. Are you attempting to fix a problem or inprove performance?
Old Sep 27, 2006 | 08:31 PM
FE352's Avatar
FE352
I want to improve performance. A little better exceleration. I was also thinkin about throwin in a converter to the mix.
Brandon
Old Sep 27, 2006 | 08:52 PM
Conanski's Avatar
Conanski
Shift kit won't improve acceleration any, though I do recommend them regardless, they will prolong the life of the tranny. What final gearing do you have? That will impact the performance the most.
Old Sep 27, 2006 | 09:24 PM
FE352's Avatar
FE352
You know thats a good question... How do I find out?
Brandon
Old Sep 27, 2006 | 09:35 PM
Fordman_Evs's Avatar
Fordman_Evs
There will be a axle code on the inside of the drivers side door (assuming they haven't been changed). I'm going to assume you have 3.55 they seem to be standard on f150 4x4's.
Old Sep 27, 2006 | 09:41 PM
FE352's Avatar
FE352
Well when he said final gear I thought he ment 4th gear in the tranny. Yeah its a 3.55 rear end ratio.
Brandon
Old Sep 27, 2006 | 09:50 PM
Fordman_Evs
Oh that could be but I think he meant rear-end ratio. I think your E4OD has somewhere between .67 and .72 final drive (overdrive), I'm not sure Conanski will know. When is the last time your truck had a tune-up? Plugs, wires, cap and filters can make a different, also clogged exhaust can be a culprit.
Old Sep 27, 2006 | 09:59 PM
FE352's Avatar
FE352
10,000 miles ago complete tune up, 3,000 miles ago I pulled everything from the cat-back off and put a straight pipe on. Its not clogged, it fact it runs factory new. I just want a lil pep is all. I'm the seconde owner of the truck the first guy kept detailed maintence records, and was an older fella so he was easy on it too.
Brandon
Old Sep 27, 2006 | 10:07 PM
Fordman_Evs
Cool! I was checking some of the commonly over looked things. Well, in that case you may consider a re-gear I know that for myself it seems the way to go. I have a 5.0L manual w/ 3.55LS on 31's and it seems sluggish to me. So, I'm going to a 4.11LS. It should make my truck much quicker off the line.
Old Sep 27, 2006 | 10:24 PM
FE352's Avatar
FE352
Yeah, if I regear it will only be to a 3.73, anything lower will be to cost prohibitive for me. I commute 60 miles aday.
Brandon
Old Sep 28, 2006 | 08:11 AM
Conanski's Avatar
Conanski
Long tube headers will provide a nice low rpm torque boost for both the 5.0 motors... exactly where they need it at hwy speeds in OD.
Old Sep 28, 2006 | 11:35 AM
radramrod2's Avatar
radramrod2
Not really worth adding exhaust work to an inline six, since they don't rev much past 3k anyway, but a transmission shift kit is worth while, and they do help in acceleration, E4OD's have a terrible lag when going from 2-3, in part because of Ford's first attempt for imperceivable shifts, I put in a TransGo shift kit in my 94 4.9L/E4OD, and it makes a huge difference, word of caution, set it up for towing and not racing, unless you like incredibly hard shifts, ALLLLL the time, even in reverse! Advance initial timing to around 14 degrees, makes it more snappy off the line, but beware of pinging. Mine does not do it at 14, but did at 16.
I'd recommend a regear over any exhaust work or intake tubes and stuff like that, if you really want more "fun" in your truck. You may pay the extra though in gas mileage, depends, don't expect any better than what you have now, lets put it that way.
Old Sep 28, 2006 | 04:39 PM
FE352's Avatar
FE352
Yeah, this truck is my work truck and commuter. So no "fun" with it, I have a 65 f100 for that. Infact the only reason this truck is 4X4 is because i live off 10 miles of dirt road, and we dont get the roads plowed or anything.
Brandon
P.S. Would a converter with a 1800 RPM stall speed be a bit much, or should I go with a 2000 RPM?
Old Sep 28, 2006 | 06:57 PM
Blurry94's Avatar
Blurry94
If the stall speed isn't an issue for you, you'll want the converter to stall where the engine makes its peak torque. If this is actually an electronic trans, a lock-up type torque converter might be your best option. The converter will act like your stock unit while cruising, it wont heat the trans fluid up as much and the motor wont use as much fuel as it would with a non-locking torque converter.
